cdnadmin
Community Member
This document was generated from CDN thread
Created by: null on 06-05-2005 01:56:30 PM
I understand that custom code needs to be compiled against java 1.3.1. When is 1.4+ likely to be supported as I find this restriction quite inconvenient?
Also, does this mean that I sould compile with the 1.3.1 compiler or if I can just specify the target version as 1.3 with a more recent compiler?
Subject: RE: Custom Code and Java Versions
Replied by: null on 12-05-2005 08:55:06 AM
It would be really helpful to get a response on this.
Alan
Replied by: Michael Bochynski on 12-05-2005 04:32:31 PM
Hi Alan,
Note that Java 1.4.1 is certified to run Audium Call Services. However, certain application servers, such as Webshpere 4.0 and Resin, might require Java 1.3 to run. I would suggest checking the J2EE version used by your application server. If your application server uses J2EE 1.3, which includes J2SE 1.4, you should be able to compile and run your code against Java 1.4.
Audium plans to introduce full support for Java 1.4 in the future release of Audium Call Services, however the target version has not beem specified at this point.
Hope this helps,
Michael
Replied by: null on 13-05-2005 09:01:35 AM
Hi, thanks but that doesn't really answer my question. I'm talking specifically about custom code. In the Installation Guide distributed with the Audium Studio & Call Services Complete Documentation Package it says...
[quote:a7504d8fb2]Important Note: While Java 1.4.1 J2SE is certified to run Audium Call Services, custom java code must be compiled against J2SE 1.3.1.[/quote:a7504d8fb2]
I don't really understand how this requirement could arise and it is a little inconvenient, but specifically, my questions are:
[list:a7504d8fb2]1. Does this instruction stand? Even if you are using say Tomcat 5.0.24 and java 1.4.1?
2. If it does, is it sufficient to use a 1.4.1 compiler just setting the target version to 1.3?
3. When is this restriction likely to be lifted?[/list:u:a7504d8fb2]
If its of any use, our target production environment will be, Tomcat 5.0.24 and J2SE 1.4.1.
Replied by: Michael Bochynski on 13-05-2005 03:43:16 PM
Hi Alan,
We have seen issues with running Audium and your custom code compiled against Java 1.4. Once the code was compiled against Java 1.3, the issues disappeared.
Note, however, that we have customers successfully running custom code compiled against Java 1.4. Your code might run without any problems, especially considering the fact that you will be using Java 1.4 as a runtime environment for Call Services.
Specifying Java 1.3 as target version should be sufficient, as long as you follow the Sun's guidelines posted in the j2SE Documentation at:
http://java.sun.com/j2se/1.4.2/docs/tooldocs/windows/javac.html
Answering your last question, Audium plans to introduce full support for Java 1.4 in the future release of Audium Call Services, however the target version has not been specified at this point.
Michael
Replied by: null on 16-05-2005 02:21:03 PM
Thanks!
Alan
Replied by: null on 22-02-2006 01:34:07 PM
Any update on this?
I'm running 3.4.3 now and would still like to be able to move to 1.4.
Replied by: Michael Bochynski on 22-02-2006 07:59:04 PM
Alan,
As I mentioned previously, we have customers compiling custom code against Java 1.4 and running it without any problems on Audium Call Services 3.4.X.
However, we strongly suggest testing this configuration in staging environment.
Please also contact your Audium Account Manager for details in regards to full Java 1.4 support.
Michael
