Heads Up :
The post you are writing will appear in a public forum. Please ensure all content is appropriate for public consumption. Review the employee guidelines for the community here.
Created by: null on 05-10-2006 12:48:38 AM Thanks Michael for your info.
once I created the java code I will convert into jar then I can add jar file into audium . studio.elements. core then it will reflect in the element pane. Am i correct please let me know
Subject: RE: Custom Element Replied by: Michael Bochynski on 05-10-2006 03:56:07 PM Hi Kumar,
You can deploy your new element either as a global element or local element. Global elements will be available in Studio for all applications, while local elements will exist for on e particular application only.
Please refer to the Following Knowledge Base Article for further details and where to put the custom code:
Subject: custom element Replied by: null on 09-10-2006 10:37:05 AM Hi Michel,
thanks. I am able to see my custom element in Audium.
thx for your help
Subject: RE: custom element Replied by: Michael Bochynski on 09-10-2006 04:14:46 PM Hi Kumar,
Not a problem. Glad that I could help.
I encourage you to look at the sample code and browse through the Audium Knowledge Base articles as well as the General Forum, since you might find it helpful during your work with Audium products.
