Heads Up :
The post you are writing will appear in a public forum. Please ensure all content is appropriate for public consumption. Review the employee guidelines for the community here.
I need some guidance in writing a custom form element. How do you store the nbestinterpretation and slot data? Is it done automatically by Audium or have to done thru Java? Do you have a sample customized form element?
Thanks, Luong.
Subject: RE: Custom Form element Replied by: Vance Vagell on 24-07-2006 09:57:46 PM Hi Luong,
Rather than creating a new Form element from scratch, we recommend that you extend our built-in Form element to add any additional functionality you might need. We have sample Java code that demonstrates how this can be done. Please download the ExtendedElementExample.java attachment from the following Audium Support Center post:
For more information about how to create custom elements, please refer to our Programmer Guide. For detailed information about the Audium Java API (including the Voice Foundation Classes, which are used to generate VoiceXML), please refer to our Javadocs.
