cdnadmin
Community Member
Subject: RE: New Message from Janine Graves in Customer Voice Portal (CVP) - General
Replied by: Hemal Mehta on 02-10-2012 11:28:44 AM
From a pure java perspective Java 6 is largely backward compatible with Java 5 exception of some changes that may be required and may not affect most of the apps.
However if Cisco has recompiled all of their base classes on 6.0 and since we use them, it may be good idea to recompile these on 6.0.  However in the past, I have been able to get classes compiled on older java version working on the new one without any issues.   As a good practice it is better to recompile these on 6.0.  Also here are some of the new features in Java 6 which will make me rewrite some of my code on 6.0 to use some of the newer features.  There is JDBC 4.0 which is more powerful and flexible and the scripting feature which can allow for some very cool things.
* Pluggable Annotation Processing API (JSR 269)
* Common Annotations (JSR 250)
* Java API for XML Based Web Services - 2.0 (JSR 224)
* JAXB 2.0 (JSR 222)
* Web Services Metadata (JSR 181)
* Streaming API for XML (JSR 173)
* XML Digital Signature (JSR 105)
* Java Class File Specification Update (JSR 202)
* Java Compiler API (JSR 199)
* JDBC<http://www.coderanch.com/forums/f-3/JDBC> 4.0 (JSR 221)
* Scripting in the Java Platform (JSR 223)
Anyways Cisco may be able to confirm for sure as far as backward compatibility and if  they see any issues.
Hemal
From: Cisco Developer Community Forums [mailto:[email protected]]
Sent: Tuesday, October 02, 2012 11:03 AM
To: [email protected]
Subject: New Message from Janine Graves in Customer Voice Portal (CVP) - General Discussion - All Versions: Re: New Message from Matthew Reiter in Customer Voice Portal (CVP) - Genera
Janine Graves has created a new message in the forum "General Discussion - All Versions": -------------------------------------------------------------- Will cisco still support custom studio/vxml server java components that
were compiled under java 5? Or must customers recompile all their
existing java components with java 6?
To respond to this post, please click the following link: http://developer.cisco.com/web/cvp/forums/-/message_boards/view_message/7264939 or simply reply to this email.
This document was generated from CDN thread
Created by: Hemal Mehta on 02-10-2012 09:19:48 AM
Cisco,
While going through 9.0 documentation, in one place I am reading that Java 5 is the required runtime for java code.  Another Cisco document says that The VXML Server code base has been compiled with Java 6.
Please clarify if we can plan to migrate to Java 6 code and if it would be supported.
Hemal
Subject: RE: CVP 9.0 and java
Replied by: Matthew Reiter on 02-10-2012 09:39:46 AM
CVP 9.0 uses Java 6 throughout (both for compilation and at runtime). If any documentation refers to Java 5 it is wrong.
Subject: RE: New Message from Matthew Reiter in Customer Voice Portal (CVP) - Genera
Replied by: Hemal Mehta on 02-10-2012 09:45:00 AM
That’s good to know.  For a moment I was disappointed that we were still staying with Java 5.  It is mentioned in your installation and upgrade guide. Please have that corrected.
Hemal
Sent: Tuesday, October 02, 2012 9:40 AM
Subject: New Message from Matthew Reiter in Customer Voice Portal (CVP) - General Discussion - All Versions: RE: CVP 9.0 and java
Matthew Reiter has created a new message in the forum "General Discussion - All Versions": -------------------------------------------------------------- CVP 9.0 uses Java 6 throughout (both for compilation and at runtime). If any documentation refers to Java 5 it is wrong.
To respond to this post, please click the following link: http://developer.cisco.com/web/cvp/forums/-/message_boards/view_message/7263596 or simply reply to this email.
Replied by: Matthew Reiter on 02-10-2012 10:24:49 AM
I've opened a defect to have the documentation corrected.
Matthew
Subject: Re: New Message from Matthew Reiter in Customer Voice Portal (CVP) - Genera
Replied by: Janine Graves on 02-10-2012 11:02:59 AM
Subject: Re: New Message from Hemal Mehta in Customer Voice Portal (CVP) - General D
Replied by: Janine Graves on 02-10-2012 12:29:44 PM
Thanks Hemal!
