cdnadmin
Community Member
Subject: Re: New Message from Eric Tanney in Customer Voice Portal (CVP) - General D
Replied by: Janine Graves on 07-07-2010 03:36:19 PM
I'd guess that your settings or audio have an issue. Can you send a
screen shot of your settings and a screen shot of your audio (expanded)
On 7/7/2010 11:27 AM, Cisco Developer Community Forums wrote:
> Eric Tanney has created a new message in the forum "General Discussion
> - All Versions":
> I'm getting the below error while using my Record element. I had the
> badfetch error. Changed the dial-peer to use G711 and resolved that
> issue. Now this is what I get...
> Â
> 10.33.17.210.1278450137509.17149.Sales_Verification_Recording,07/06/2010
> 16:02:44.134,Member Message,element,error,A built-in element
> encountered an exception of type
> com.audium.server.voiceElement.ElementException.
> Â
> Any ideas?
> To respond to this post, please click the following link:
> <http://developer.cisco.com/web/cvp/forums/-/message_boards/message/2339619>
> or simply reply to this email.
Janine Graves
781-990-1040
Subject: RE: Re: New Message from Eric Tanney in Customer Voice Portal (CVP) - Gener
Replied by: Eric Tanney on 07-07-2010 03:44:18 PM
Here are my most recent settings. I've also tried with FTP = True
> - All Versions":
> Â
> Â
> Any ideas?
Janine Graves
781-990-1040
Replied by: Janine Graves on 07-07-2010 04:04:19 PM
Are you sure you have a d:\test\ directory? and that you have priveleges
to write to it?
If you still can't get it to work, try creating a vxml debug log and
send the vxml being created.
> - All Versions":
> Â
> Â
> Â
> Â
> > - All Versions":
> > ÿ
> > ÿ
> > Any ideas?
> Janine Graves
> 781-990-1040
> <http://developer.cisco.com/web/cvp/forums/-/message_boards/message/2338001>
Janine Graves
781-990-1040
Replied by: Eric Tanney on 07-07-2010 05:17:55 PM
Wow. Removing it entirely did the trick! Thanks!!!
I don't put anything into the File Extension setting (when empty,
VxmlServer puts the .wav ext by default).
But, I would guess that if you do use the File Extension setting, that
you should omit the leading dot, enter 'wav' instead of '.wav' (omit
quotes).
Let me know if that works.
> - All Versions":
> Â
> Â
> Â
> Â
> > - All Versions":
> > ÿ
> > ÿ
> > Any ideas?
> Janine Graves
> 781-990-1040
Janine Graves
781-990-1040
Replied by: Eric Tanney on 07-07-2010 05:35:34 PM
Ok so now I get this error when updating the vxml app... any thoughts?
An error has occurred.  Please make sure the application server is running and t
ry this command again.
quotes).
> - All Versions":
> Â
> Â
> Â
> Â
> > - All Versions":
> > ÿ
> > ÿ
> > Any ideas?
> Janine Graves
> 781-990-1040
Janine Graves
781-990-1040
This document was generated from CDN thread
Created by: Eric Tanney on 07-07-2010 03:27:43 PM
I'm getting the below error while using my Record element. I had the badfetch error. Changed the dial-peer to use G711 and resolved that issue. Now this is what I get...
10.33.17.210.1278450137509.17149.Sales_Verification_Recording,07/06/2010 16:02:44.134,Member Message,element,error,A built-in element encountered an exception of type com.audium.server.voiceElement.ElementException.
Any ideas?
Replied by: Janine Graves on 07-07-2010 03:52:55 PM
quotes).
> - All Versions":
> Â
> Â
> Â
> Â
> > - All Versions":
> > ÿ
> > ÿ
> > Any ideas?
> Janine Graves
> 781-990-1040
Janine Graves
781-990-1040
Replied by: Janine Graves on 07-07-2010 05:53:19 PM
sounds like tomcat crashed due to too many errors or too little memory.
just restart the Cisco Vxml Server Service (in Windows Services) and try
again.
> - All Versions":
> Â
> running and t
> Â
> quotes).
> > - All Versions":
> > ÿ
> > ÿ
> > ÿ
> > ÿ
> > > - All Versions":
> > > ÿ¿
> > > ÿ¿
> > > Any ideas?
> > Janine Graves
> > 781-990-1040
> Janine Graves
> 781-990-1040
> <http://developer.cisco.com/web/cvp/forums/-/message_boards/message/2338264>
Janine Graves
781-990-1040
Replied by: Eric Tanney on 07-07-2010 06:01:22 PM
Yup, that's what happened. Can I not save a message with the session data as the name?
again.
> - All Versions":
> Â
> running and t
> Â
> quotes).
> > - All Versions":
> > ÿ
> > ÿ
> > ÿ
> > ÿ
> > > - All Versions":
> > > ÿ¿
> > > ÿ¿
> > > Any ideas?
> > Janine Graves
> > 781-990-1040
> Janine Graves
> 781-990-1040
Janine Graves
781-990-1040
Replied by: Janine Graves on 07-07-2010 07:22:19 PM
might depend upon what's in the session data variable. perhaps it's not
a valid file name.
I've used variables in the name of a recording, so it works if it's valid.
> - All Versions":
> data as the name?
> Â
> again.
> > - All Versions":
> > ÿ
> > An error has occurred.ÿ Please make sure the application server is
> > running and t
> > ÿ
> > quotes).
> > > - All Versions":
> > > ÿ⿿
> > > ÿ⿿
> > > ÿ⿿
> > > ÿ⿿
> (expanded)
> Discussion
> > > > - All Versions":
> > > > ÿƿÿ¿
> > > > ÿƿÿ¿
> > > > Any ideas?
> > > Janine Graves
> > > 781-990-1040
> > Janine Graves
> > 781-990-1040
> Janine Graves
> 781-990-1040
> <http://developer.cisco.com/web/cvp/forums/-/message_boards/message/2340338>
Janine Graves
781-990-1040
