Heads Up :
The post you are writing will appear in a public forum. Please ensure all content is appropriate for public consumption. Review the employee guidelines for the community here.
Created by: deniz caglar on 13-07-2009 03:25:28 PM Hi, I have a problem about cvp reporting. I have an application in call studio. And i create some reports using some sql's against cvp reporting server.I write a simple sql like: select * from VXMLElement where elementname = "Audio_129" Some of fields like exitdatetime, numberofinteraction,resultid, exit state are empty. I am attaching the results of the sql. But in activitylog in \\vxmlserver\c$\Cisco\CVP\VXMLServer\applications\MYAPPLICATION\logs\ActivityLog i can see that flow achieved to pass this element successfully, as you can see below: 10.231.16.145.1247497686526.163.IVR_AloGaranti_Deniz,07/13/2009 18:08:54.481,Audio_129,enter, 10.231.16.145.1247497686526.163.IVR_AloGaranti_Deniz,07/13/2009 18:08:54.481,Audio_129,custom,xxx,xxx 10.231.16.145.1247497686526.163.IVR_AloGaranti_Deniz,07/13/2009 18:08:54.489,Audio_129,interaction,audio_group,initial_audio_group 10.231.16.145.1247497686526.163.IVR_AloGaranti_Deniz,07/13/2009 18:08:54.653,Audio_129,exit,done
So, why can not i take these fields in my report ? Thanks, Deniz
Subject: RE: cvp reporting problem Replied by: Eric Tanney on 15-07-2009 05:14:49 PM Does this happen for every element type in your table, or only specific to "AUDIO_129"?
Subject: RE: cvp reporting problem Replied by: deniz caglar on 16-07-2009 06:45:05 AM It changes, i made a new sql giving different elementtypes to see if they also have the problem, i saw that not only a spesific audio element, but a desicion, menu, custom vs elements have this problem. I am attaching a new file that shows different elements have this problem (ElementProblem2). For example: One element called Decision_PaymentType is a decision element that i decide an action looking to a session variable. This element has three exit states: Card, Account and Technical Error. In my sql, only the Card exitstates are available. I made a sample call that i provide this decision element to exit with Account exitstate and i saw in the activity log that exit state is Account as shown below, but in the reporting server its resultid and exitstate columns are empty. I am also attaching the sql results of this element(Decision_PaymentType_Element.xls). You can look at the last raw at 07/16/2009 09:30 which is the same call of the activity log below. ... 10.231.16.145.1247725812573.106.IVR_AloGaranti_Deniz,07/16/2009 09:30:49.590,Audio_TxnReadAccont,exit,done 10.231.16.145.1247725812573.106.IVR_AloGaranti_Deniz,07/16/2009 09:30:49.590,Decision_ReturnCaller,enter, 10.231.16.145.1247725812573.106.IVR_AloGaranti_Deniz,07/16/2009 09:30:49.590,Decision_ReturnCaller,exit,MobileTopUp 10.231.16.145.1247725812573.106.IVR_AloGaranti_Deniz,07/16/2009 09:30:49.590,Decision_PaymentType,enter, 10.231.16.145.1247725812573.106.IVR_AloGaranti_Deniz,07/16/2009 09:30:49.590,Decision_PaymentType,exit,Account 10.231.16.145.1247725812573.106.IVR_AloGaranti_Deniz,07/16/2009 09:30:49.590,SetAccountInfoForMobilePayment_01,enter, ... Thanks.
Subject: RE: cvp reporting problem Replied by: Manoj Anantha on 05-08-2009 02:20:35 PM I experienced similar issue and fixed it. What i had done was in one of my custom element I was storing a hugh object (web service object) into a session variable. When removed this issue was fixed. If you have any custom element where you are setting a session variable other then String this is bound to happen. Please let me know if you have any custom element? if yes post the code.
