cdnadmin
Community Member
This document was generated from CDN thread
Created by: Selim Budakoglu on 27-11-2008 05:02:08 PM
Hi guys,
I have been trying to call web service which I developed by using Microsoft .Net 2008 visual studio, from CVP 7.0.1 platform and I am getting the following error, does anyone has any idea. Thanks...
10.81.110.81.1227804397993.3.WS3,11/27/2008 18:46:38.008,The error was: SOAP 1.2 Binding with null invocation parameter is not allowed with HTTP POST Request Method in MESSAGE mode The error was:
The root cause was: javax.xml.ws.WebServiceException: SOAP 1.2 Binding with null invocation parameter is not allowed with HTTP POST Request Method in MESSAGE mode
com.audium.server.AudiumException:
at com.audium.server.webservices.ServicesDispatcher.logEnvelopes(ServicesDispatcher.java:258)
at com.audium.server.webservices.ServicesDispatcher.invoke(ServicesDispatcher.java:205)
at com.audium.server.webservices.WebservicesElement.invokeService(WebservicesElement.java:52)
at com.audium.server.voiceElement.WebservicesElementBase.service(WebservicesElementBase.java:395)
at com.audium.server.controller.Controller.goToWebservices(Controller.java:2667)
at com.audium.server.controller.Controller.goToElement(Controller.java:2456)
at com.audium.server.controller.Controller.enterVoiceApplication(Controller.java:1007)
at com.audium.server.controller.Controller.newCall(Controller.java:944)
at com.audium.server.controller.Controller.doPost(Controller.java:469)
at com.audium.server.controller.Controller.doGet(Controller.java:398)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:690)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:803)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:269)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:188)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:210)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:174)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:127)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:117)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:108)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:151)
at org.apache.coyote.http11.Http11AprProcessor.process(Http11AprProcessor.java:834)
at org.apache.coyote.http11.Http11AprProtocol$Http11ConnectionHandler.process(Http11AprProtocol.java:640)
at org.apache.tomcat.util.net.AprEndpoint$Worker.run(AprEndpoint.java:1286)
at java.lang.Thread.run(Thread.java:595)
Root Cause: javax.xml.ws.WebServiceException: SOAP 1.2 Binding with null invocation parameter is not allowed with HTTP POST Request Method in MESSAGE mode
at com.sun.xml.ws.client.dispatch.DispatchBase.isValidNullParameter(DispatchBase.java:624)
at com.sun.xml.ws.client.dispatch.DispatchBase.setupMessageStruct(DispatchBase.java:400)
at com.sun.xml.ws.client.dispatch.DispatchBase.invoke(DispatchBase.java:118)
at com.audium.server.webservices.ServicesDispatcher.invoke(ServicesDispatcher.java:173)
Edited by: Selim Budakoglu on Nov 27, 2008 12:07 PM
Subject: Re: CVP Web Sevice problem
Replied by: Selim Budakoglu on 27-11-2008 06:19:42 PM
Hi again,
We have just solved the problem. We had to update our client and server system to 7.0.2 patch.
Subject: RE: Re: CVP Web Sevice problem
Replied by: Sherif Amer on 01-11-2009 01:19:58 PM
Dear selim,
i have the same problem but my web service in java
i want to ask you some questions which may help me:
1-SAOP version that u used in the webservice.?
2-can you send me the WSDL file that you used ?
willwatts
Community Member
WebServices Element and .Net Webservices has an example of how this breaks for CVP 9.0(1) using a HttpPost port in the WebService element.
