cdnadmin
Community Member
This document was generated from CDN thread
Created by: Gerard O'Rourke on 04-06-2013 07:17:09 AM
Am I right in thinking that there is no way to explicity set a timeout value for the standard database element, either explicty for that particular element or globally (by setting a gobal timeout value)?
Also is any way for the standard database element to capture an connection error except by configuring a CVP Sub Dialog return and setting it as an error element?
i.e. to do either of above properly you need to develop a custom database element?
Gerry
Subject: RE: New Message from Gerard O'Rourke in Customer Voice Portal (CVP) - Gener
Replied by: Hemal Mehta on 04-06-2013 08:16:41 AM
You can set the global fetchtimeout  however that applies to vxml gateway only. Also you can set timeout in the Tomcat config file which is the timeout for DB connection.  However that is only for the time it takes to connect to DB.
If you want timeout for your particular query, it is best to have your own custom code.
Hemal
From: Cisco Developer Community Forums [mailto:[email protected]]
Sent: Tuesday, June 04, 2013 7:17 AM
To: [email protected]
Subject: New Message from Gerard O'Rourke in Customer Voice Portal (CVP) - General Discussion - All Versions: Database Element - Connection Timeout 16 seconds
Gerard O'Rourke has created a new message in the forum "General Discussion - All Versions": -------------------------------------------------------------- Hi,
Gerry
To respond to this post, please click the following link: http://developer.cisco.com/web/cvp/community/-/message_boards/view_message/15848371 or simply reply to this email.
