cdnadmin
Community Member
This document was generated from CDN thread
Created by: Cory Wright on 05-05-2006 07:55:40 PM
Janine wrote in and asked the following:
Where would I find the database schema for the database created by the importlogs script?
I thought others might also want to see the answer when it comes up, so I'm posting it here...
Cory
Subject: RE: Database Schema question from script
Replied by: Michael Bochynski on 08-05-2006 03:58:09 PM
The activity importer script creates only one table - activity_log. The column specification is as follows (MySQL):
[code:1:e286fbceb9]
  Field     Type     Null     Key     Default     Extra
  session_id     varchar(100)
  activity_time     datetime             0000-00-00 00:00:00
  element     varchar(100)     YES         NULL
  category     varchar(50)     YES         NULL
  action     varchar(50)     YES         NULL
  value     varchar(100)     YES         NULL
[/code:1:e286fbceb9]
Note that I have also entered this issue into our internal bug tracking system to add this description to our documentation.
Thanks for pointing it out!
Michael
Replied by: null on 08-05-2006 09:25:18 PM
I had noted the structure of the activity_log table for SQL Server in the following thread:
http://www.audiumcentral.com/supportcenter/viewtopic.php?t=1077
Geoff
