Heads Up :
The post you are writing will appear in a public forum. Please ensure all content is appropriate for public consumption. Review the employee guidelines for the community here.
Created by: Lewis Mackey on 30-03-2009 09:11:23 PM I need help understanding what is causing this debug error below. I viewed the global error log, but its contents were not meaningful to me. I have attached the global error log file to see if anyone can help. Thanks!
*** An error occurred while loading application 'SOTAutoAttendant'. The error was: There was a problem loading classes local to the application SOTAutoAttendant. Please see the global error log in AUDIUM_HOME/logs for more details about this error. This application will be unavailable until the problem is fixed. Note that this does not affect any other voice applications. ***
Subject: RE: Debug Call Studio Project Error Replied by: Janine Graves on 30-03-2009 09:29:03 PM It looks like your application is trying to invoke an 'End of Call' class com/eloyalty/Audium/Call/API/CallEnd, but Vxml Server can't find it. If it's local to the app, then it should be in the VxmlServer/applications/<appname>/java/com/eloyalty/Audium/Call/API/ directory. Do you see it there? Another reason for getting the noClassDef error is if a class in the VxmlServer/common/ directory (which loads before the application specific java classes at startup) is referencing a class that is in an app-specific directory. Janine
Subject: RE: Debug Call Studio Project Error Replied by: Lewis Mackey on 30-03-2009 09:43:08 PM I not yet deployed my application to the VXML server. I was trying to debug the application that resides on my development workstation. Do I need to deploy before I can debug?
Subject: Re: New Message from Lewis Mackey in Customer Voice Portal (CVP) - General Replied by: Janine Graves on 30-03-2009 10:11:51 PM No. But in that case, replace 'VxmlServer\' directory my previous response with 'C:\Cisco\CallStudio\eclipse\plugins\com.audium.debugger.runtime\'
FYI - not everything runs in the debugger. App Transfers, Subdialog Invoke, the Database element, to name a few.
Cisco Developer Community Forums wrote: > Lewis Mackey has created a new message in the forum "General > Discussion - All Versions": > > -------------------------------------------------------------- > I not yet deployed my application to the VXML server. I was trying to > debug the application that resides on my development workstation. Do I > need to deploy before I can debug? > -- > To respond to this post, please click the following link: > > <http://developer.cisco.com/web/cvp/forums/-/message_boards/message/1246836> > > or simply reply to this email.
Subject: RE: Re: New Message from Lewis Mackey in Customer Voice Portal (CVP� Replied by: Lewis Mackey on 31-03-2009 08:23:09 PM How do I configure a build/class path for Call Studio project's run-time environment? I believe my error is because the project cannot reference a certain jar file.
Subject: Re: New Message from Lewis Mackey in Customer Voice Portal (CVP) - General Replied by: Janine Graves on 31-03-2009 09:09:51 PM I don't think you can change Studio's classpath. You can modify Tomcat's though.
If you put your java in one of the locations listed below, you should be all set. (And if you're trying to use the debugger instead of VxmlServer, then replace the 'VXMLServer' directory with the C:\Cisco\CallStudio\eclipse\plugins\com.audiumcorp.studio.debug.runtime_6.0.1\AUDIUM_HOME)
(from a response by Elam Birnbaum of Cisco to a previous post on the forum):
Keep in mind that VXML Server will explicitly load all of the classes in the JAR files stored in its VxmlServer/common/lib and the VxmlServer/applications/<appname>/java/application/lib folders. This involves loading the classes into memory so that when an instance is needed of the class it does not require loading from a file. What this does, however, is add to the memory footprint and for libraries that will not change and are not directly related to the VXML Server application it may not be necessary.
Here are some places where you may wish to try to put these JARs:
* If the JARs are not necessarily dependent on the application, you can put these JARs in the classpath for the application server itself. For example with Tomcat, the Tomcat folder contains its own common/lib in which you can place these JARs. * The JAR files placed in the VXMLServer/applications/<appname>/java/util/lib folder are not explicitly loaded like classes in the VXMLServer/applications/<appname>/java/application/lib directory so they will not take up memory. They are, however, added to the classpath so will be loaded as needed. This option allows one to keep JARs partitioned on a per-application basis without the memory overhead of loading all the classes.
Cisco Developer Community Forums wrote: > Lewis Mackey has created a new message in the forum "General > Discussion - All Versions": > > -------------------------------------------------------------- > How do I configure a build/class path for Call Studio project's > run-time environment? I believe my error is because the project cannot > reference a certain jar file. > -- > To respond to this post, please click the following link: > > <http://developer.cisco.com/web/cvp/forums/-/message_boards/message/1250319> > > or simply reply to this email.
Subject: RE: Re: New Message from Lewis Mackey in Customer Voice Portal (CVP� Replied by: Moiz Siddiqui on 14-04-2009 09:08:34 AM Hi, Put all the beans/ common objects at the location specified by Janine i.e C:\Cisco\CallStudio\eclipse\plugins\com.audiumcorp.studio.debug.runtime_6.0.1\AUDIUM_HOME\ [YOUR CLASS FOLDER STRUCTURE FOR BEANS] and it will work. Have you tried testing you application on the server itself. If it is the case which i have mentioned then you application will not even work on the server. For this specific case, on server you have to deploy the same common classes to \Cisco\CVP\VXMLServer\common\classes e.g in my application, structure was something like this \Cisco\CVP\VXMLServer\common\classes\com\avanza\icm\integration\model\ while model contains all the beans Hope this might help Regards, Moiz
