Robert Thomas
Level 9
Level 9
Background
While troubleshooting no audio problems with IP phones it may come in handy to enable an rtp debug directly on the ip phone. This other document explains how to login to an ip phone for debugging.
Enable the Debug
First access debugsh mode.
$ debugsh
With the keyword debug you can display the different debugs available at the ip phone.
0021555384FA> debug
The following subcommands are available under 'debug':
  debug all
      Enable/Disable all debugging
  debug dhcp
      Enable dhcp process debug settings
  debug cdp
      Enable cdp process debug settings
  debug flashfs
      Enable flashfs process debug settings
  debug dsp
      Enable dsp process debug settings
  debug dns
      Enable dns process debug settings
  debug inetd
      Enable inetd process debug settings
  debug jvm ALL
      NOTICE
  debug jvm AppStatus
      NOTICE
  debug jvm AutoService
      NOTICE
  debug jvm Application
      NOTICE
  debug jvm CallUI
      NOTICE
  debug jvm Config
      NOTICE
  debug jvm Component
      NOTICE
  debug jvm Http
      NOTICE
  debug jvm MediaManager
      NOTICE
  debug jvm Localization
      NOTICE
  debug jvm Graphics
      NOTICE
  debug jvm MIDP-LCDUI
      NOTICE
  debug jvm MIDP-MIDlet
      NOTICE
  debug jvm MIDP-Media
      NOTICE
  debug jvm MIDP-RMS
      NOTICE
  debug jvm MIDP-PushRegistry
      NOTICE
  debug jvm MIDP-MIDletSuite
      NOTICE
  debug jvm MIDP-IO
      NOTICE
  debug jvm CallAgent
      NOTICE
  debug jvm SCCP
      NOTICE
  debug jvm PushService
      NOTICE
  debug jvm Services
      NOTICE
  debug jvm SideCar
      NOTICE
  debug jvm Settings
      NOTICE
  debug jvm Security
      NOTICE
  debug jvm SubscriptionFramework
      NOTICE
debug jvm Tftp
      NOTICE
  debug jvm System
      NOTICE
debug jvm Util
      NOTICE
  debug jvm XML
      DEBUG
  debug jvm Video
      NOTICE
  debug jvm UserIO
      NOTICE
  debug jvm StartUp
      NOTICE
  debug jvm Properties
      NOTICE
  debug init
      Enable init process debug settings
  debug ntp
      Enable ntp process debug settings
  debug secd
      Enable secure daemon debug settings
  debug process
      Enable process process debug settings
  debug ui
      Enable UI debug setting
  debug tftpClient
      Enable tftpClient process debug settings
  debug netkern
      Enable netkern process debug settings
  debug imageauth
      Debug imgauthd process
For this specific case we would like to enable the following debugs.
0021555384FA> debug dsp rtp
        Sending SIGUSR2 to dsp
0021555384FA> debug jvm MediaManager
0021555384FA> debug jvm SCCP
/usr/local/trace/log.propertiesSuccessfully executed the command.
After you have enabled the debugs that interest you, exit the debug subsystem by quitting.
0021555384FA> quit
/usr/local/trace/log.propertiesSuccessfully executed the command.Exiting shell...
Logging out...
Use the command strace to begin the debugging session. The following is an example of the output.
$ strace
strace: PID = 23, ver A
|=== Syslogd === Tue Feb  8 14:57:40 2011
NOT 14:57:40.295775 JVM: Startup Module Loader|cip.cfg.r:? - CUCM in config file: #1 XmlCallAgentObject: IPv4-name=
NOT 14:57:40.297314 JVM: Startup Module Loader|cip.cfg.r:? - CUCM in config file: #2 XmlCallAgentObject: IPv4-name=
NOT 14:57:40.298917 JVM: Startup Module Loader|cip.cfg.r:? - CUCM in config file: #3 XmlCallAgentObject: IPv4-name=
NOT 14:57:40.300882 JVM: Startup Module Loader|cip.cfg.r:? - CUCM in config file: #4 XmlCallAgentObject: IPv4-name=
DBG 14:57:40.302438 JVM: Startup Module Loader|cip.sec.CapfProperty:? - CAPF IPv4 :CAPF IPv6 :CAPF Mode :0CAPF Port
ERR 14:57:40.304045 JVM: Startup Module Loader|cip.sec.CapfProperty:? - Failed to resolve Capf Ipv4 Address with ho
ERR 14:57:40.305792 JVM: Startup Module Loader|cip.sec.CapfProperty:? - Failed to resolve Capf Ipv6 Address with ho
DBG 14:57:40.307761 JVM: Startup Module Loader|cip.sec.CapfProperty:? - CAPF IPv4 :CAPF IPv6 :CAPF Mode :0CAPF Port
ERR 14:57:40.309298 JVM: Startup Module Loader|cip.sec.CapfProperty:? - No valid CAPF server
NOT 14:57:40.311526 JVM: Startup Module Loader|cip.cfg.r:? - Config processConfigNoError() result code=CONFIG_FILE_
NOT 14:57:40.314206 SECD: setSecMode: sec mode set to NONE (was NONE)
NOT 14:57:40.604631 JVM: Startup Module Loader - Deletion of file Successful/usr/ram/SEP0021555384FA.cnf.xml
Collect the previous output and report it back to the TAC center.
