cdnadmin
Community Member
This document was generated from CDN thread
Created by: SEAN NILSEN on 19-03-2009 05:39:48 PM
Running CVP 4.1, is there a way to get at the Exit State value for that Element?
I am resorting to setting session data because I can not find a reference to the structure of the Decision Element.
I am also assuming that I am just unaware of the right data element to grab.
These don't work:
{Data.Element.<Element Name>.result}
{Data.Element.<Element Name>.exit_state}
{Data.Element.<Element Name>.Result}
{Data.Element.<Element Name>.Exit_State}
{Data.Element.<Element Name>.RESULT}
{Data.Element.<Element Name>.EXIT_STATE}
Thanks in advance!
Subject: Re: New Message from SEAN NILSEN in Customer Voice Portal (CVP) - General D
Replied by: Janine Graves on 19-03-2009 09:36:57 PM
You can access the exit state(s) in the Java code (you can get objects
which are almost like arrays of ElementHistory and ExitStateHistory -
the ElementHistory contains the name of every element visited (in
order), the ExitStateHistory has the name of each exit state followed
from the corresponding element).
But it's essentially impossible from the graphical Studio tool.  So, if
you don't want to resort to Java, then you should probably set a
variable to have different values when you follow different exit states
off the elements. This isn't always so pretty to look at though.
If you know a little Java, the CVP Java API is actually pretty easy to
work with.
Janine
www.TrainingTheExperts.com
Cisco Developer Community Forums wrote:
> SEAN NILSEN has created a new message in the forum "General Discussion
> - All Versions":
> that Element?
> Â
> Â
> grab.
> Â
> These don't work:
> Â
> Â
> Thanks in advance!
> To respond to this post, please click the following link:
> <http://developer.cisco.com/web/cvp/forums/-/message_boards/message/1199764>
> or simply reply to this email.
Subject: RE: Re: New Message from SEAN NILSEN in Customer Voice Portal (CVP
Replied by: SEAN NILSEN on 23-03-2009 06:21:57 PM
Thanks for your expertise Janine!
