Heads Up :
The post you are writing will appear in a public forum. Please ensure all content is appropriate for public consumption. Review the employee guidelines for the community here.
Created by: null on 19-07-2005 03:48:29 PM Can I change the default audio path within an Action Element?
Thanks, Dan
Subject: RE: Default Audio Path Replied by: Vance Vagell on 19-07-2005 04:48:02 PM Hi Daniel,
Yes, you can change many Audium settings from within an Action element. To change the default audio path, use the method setDefaultAudioPath(String path). Call this method on the ActionElementData object that is passed to the doAction method of your Action element's class. Note that ActionElementData inherits this method from APIBase.
