This document was generated from CDN thread
Created by: adam poszich on 30-05-2012 02:24:23 AM
is xcommand Dial the only way to place a call of can i some how dial a ContactId: from the phonebook search results.
Subject: RE: dial a ponebook entry
Replied by: null on 30-05-2012 08:46:42 AM
Hi Adam,
yes, you have to get the number from the phone book and then use it in the xCommand Dial Number:"xxx" command.
David
