cdnadmin
Community Member
This document was generated from CDN thread
Created by: null on 22-02-2005 01:43:20 AM
Having run a "hello world" type app, there appears to be no difference between the logging settings of "moderate" and "complete". Should there be a difference?
Subject: RE: Difference between moderate and complete logging
Replied by: null on 22-02-2005 03:48:07 AM
Have just looked at the User Guide (3.3, chapter 6, page 103) - it shows a table describing differences in logging levels.
Replied by: null on 22-02-2005 05:47:14 PM
Yes, when you call into HelloWorld, ou will not see a difference because there is not interaction logging. In the 3.4 documentation you should also see that table you refer to (its a different chapter now, but the table is the same).
If you called into AgeIdentification, you would see the difference as the one with moderate logging will not show information such as the utterance and interpretation.
