cdnadmin
Community Member
This document was generated from CDN thread
Created by: soundararajan t on 19-03-2011 12:12:27 PM
I am installing profile 52" single with C60 codec.DVI port is connected to TV via DVI to HDMI cable.
Once codec is rebooted system OSD is not appear on 2nd DVI port each and every time we will change the OSD port by pressing the remote *#*#02#.Is it possible to store the OSD on second display port permanently.
Subject: RE: Display OSD output
Replied by: Johan Randby on 21-03-2011 10:48:03 AM
Hi Soundara
Which software version are you running? Are you running any scripts etc to customize layouts/outputs, or is everything default?
Correct behavior should be that when you change the OSD output, the setting should persist after a reboot.
BR
Johan
Replied by: soundararajan t on 22-03-2011 05:07:18 AM
Hi Johan
Software version is 4.0.0.2 and machine serial no is B1AD46C00017.
No scripts and customize layout
Thanks & Regards
Soundar
Replied by: Johan Randby on 22-03-2011 09:30:26 AM
Soundara,
Please open a support case with TAC on this matter.
Best Regards,
Johan
