cdnadmin
Community Member
This document was generated from CDN thread
Created by: null on 08-03-2007 09:15:08 PM
Does Audium require a speech engine? In looking at the Form element, the dtmf_keypress property defines an inline DTMF grammar. I currently don't have a speech engine available to me, so how can I collect input from the caller if the Form is generating grammars?
Subject: RE: Does Audium Require a Speech Engine?
Replied by: null on 09-03-2007 03:10:43 PM
whether a speech engine is required depends on how the user input is collected. VXML usually supports three input modes: dtmf, voice, and both. If all you plan to do is dtmf only, then you will not need a speech engine.
Hope this helps.
John
Replied by: null on 09-03-2007 04:40:17 PM
I understand that, but how can I collect input from an Audium application without Audium creating a grammar to do the detection? I'm trying to use a Form element, but the four input detection types (voice_grammar, dtmf_grammar, voice_keyword, and dtmf_keyword) all create grammars. The voice_grammar and dtmf_grammar both look for external grammars and the voice_keyword and dtmf_keypress both create inline grammars. The description on all four detection types say that none of the four are required, but at least one must be specified since a form cannot be completed without at least one grammar.
I have set the inputmode to dtmf, but since I don't have a speech engine available, my test application isn't recognizing the dtmf input because I'm using a Form element.
Which element(s) can I use to collect dtmf input without the need for a speech engine?
Replied by: null on 09-03-2007 10:32:59 PM
Can you tell me what VoiceXML browser you are running? Some browsers may provide a built-in DTMF recognizer. If you are working with this type of browser, you can create a Form element configured with only an external DTMF grammar source.
John
Replied by: Janine Graves on 11-03-2007 04:21:40 PM
In the Form element, you can have it create an inline DTMF grammar for you by using the setting DTMF Keypress. If you enter the number 1 for that parameter it will allow the caller to press 1. You can right-click on that setting and "Add another" to enter another allowed keypress.
Another way to go is to use the Digit or Number element to collect the input and set the Setting called "InputType" to 'dtmf'
With the Digit collection element, you'll say the min and max number of digits to collect.
With the Number element, they can enter as many digits as they want.
Is there a reason that you are using a Form rather than a Digit or Number element? Form gives you a lot of flexibility, but it might be easier for you to use a Number or Digit element.
Janine
Janine Graves
www.TrainingTheExperts.com
Replied by: null on 14-03-2007 04:26:03 PM
I've used a "Number / Digit" element to capture DTMF entries and also set input modes to DTMF. But grammer is still generated, to do the detection.
