Heads Up :
The post you are writing will appear in a public forum. Please ensure all content is appropriate for public consumption. Review the employee guidelines for the community here.
Created by: ROD TAGUCHI on 25-10-2011 09:24:40 AM I am trying to manually set some network settings with additional route statements. They keep getting overwritten. I believe that puppet is 'fixing' the ip route settings. Where in the DB would I create additional route statements?
Thanks, Rod
Subject: RE: Does puppet control network settings? Replied by: Mohsin Ali on 31-10-2011 11:49:15 PM Hi Rod,
You need to logon with admin username and password. Setup the ip/route changes needed and save and exit. Below example shows how to setup default gateway
login: admin password: Password you setup during installation conf t ip default-gateway x.x.x.x end wr mem reload
HTH,
Mo
Subject: RE: Does puppet control network settings? Replied by: ROD TAGUCHI on 01-11-2011 01:54:26 AM Mohsin Ali, will the new setting 'stick' after reboots? Thanks, Rod
Subject: RE: Does puppet control network settings? Replied by: Christopher Chandler on 17-11-2011 10:48:55 AM
Thanks, Rod
Mo's response is correct. There are a handful of OS-level settings that we revert back to the as-installed settings (going off of memory here, but I think items in resolv.conf, network config [IP addresses, default GW, etc], etc). But, this is not done by puppet. Puppet only manages application-level config (e.g.: portal-ext.properties, etc) - and it's only a handful of files. in other words, Puppet only manages a small subset of files specific to the application running on that node (WebEx Social, ActiveMQ, MongoDB, etc). Hope that helps!
