cdnadmin
Community Member
This document was generated from CDN thread
Created by: Justin Ferello on 31-01-2011 04:15:52 PM
On a C series codec, if I have a 'Y' cable can I get a digital DVI signal & RGBHV signal out of that DVI port at the same time?
Justin
Subject: RE: DVI Output
Replied by: Roger Boe on 01-02-2011 12:03:21 PM
Hi Justin,
No, you can only get one signal at the time.
Cheers
Roger
Replied by: Ravi Kr on 17-06-2011 10:15:02 PM
Hi Roger ,
i have a query can we connect a DVI-A  (projector  or monitor ) on C40 DVI -I output  ?
if yes they i am facing issues like improper image on the display just a blue cloud and nothing else.
Replied by: Jonas Tysso on 21-06-2011 12:08:32 PM
Hi Ravi,
sounds like you are just missing the OSD (On screen display) on your output. You can select the OSD by using the following xAPI:
xConfiguration Video OSD Output: n
Where n is the output you have connected your projector/monitor.
Alternatively, you can use the following remote control key sequence  (when not in a call):
"disconnect - * - # - * - # - 0 -n - #" where n is desired output to change the OSD. Notice that this procedure will also restore the resolution (1280x720@60Hz for HDMI and 1024x768@60Hz for DVI) to the selected output
Cheers,
Jonas
