cdnadmin
Community Member
This document was generated from CDN thread
Created by: null on 13-11-2005 11:12:31 PM
Have just reviewed the 3.4 User Guide and Programmers Guide, and it's not clear what the purpose of the Dynamic Configuration tick-box "Create Base Configuration" s for. Is it to make the configuration, as coded by the Studion developer, available to the code implementing the Dynamic Element? Or does it create some sort of default configuration for the code implementing the Dynamic Element? I suspect the former (in which case it might be called "make base config available", but that's a bit unweildy). Please comment.
Thanks in advance.
Subject: RE: Dynamic Elements: Create Base Configuration tick-box
Replied by: Vance Vagell on 14-11-2005 04:26:02 PM
If a voice application designer creates a base configuration, the chosen settings are passed to the custom code (i.e. the dynamic configuration class) to use or discard as needed. For example, a dynamic config class may only wish to modify the max noinput setting of an element, and therefore uses the base configuration for the other settings.
The Audium Knowledgebase Article "I am creating a dynamic configuration class, but do not want to change all settings" provides additional details about this process that you may find helpful.
Vance
