cdnadmin
Community Member
This document was generated from CDN thread
Created by: Janine Graves on 22-03-2009 04:02:55 PM
Does anyone know how I 'attach' the CVP Javadoc to a Java project that I create in Eclipse so that I can view the Javadoc from within Eclipse editor when I'm developing a custom CVP component? I get the message 'This element neither has the source nor attached Javadoc and hence no info could be found'.
Also, does anyone know how to configure a Java project in Eclipse so the compiled java class goes directly into my Studio project's deploy/java/application/classes/ folder (rather than my having to copy/paste it)?  It has to do with configuring its 'nature' in the classpath I think. Some brilliant student showed me how to do this once. I'm hoping to find another brilliant person out there knows how!
Thanks, Janine
Subject: RE: Eclipse help
Replied by: Brien Williams on 24-03-2009 07:39:13 PM
You can add the javadoc at the project level properties )or under the the more general Window ->Preferences menu.) From the popup window, you make the change to the Java Build Path in the left-hand browse tree. Pick the Libraries tab. Expand the navigation tree for the framework.jar and edit the javadoc location.
It's basically the same answer for part two of the question I think: project level change to the  Java Build Path again, but pick the Source tab this time. Change the default output folder.
Replied by: Brien Williams on 24-03-2009 07:55:29 PM
Hi Janine,
I had to go back and try the answer to that second part of your quesiton - there is a mandatory preliminary step! First add a folder to your project and using the "advanced" (that's the brilliant part : ) button, create a link to the file system.
Subject: Re: New Message from Brien Williams in Customer Voice Portal (CVP) - Genera
Replied by: Janine Graves on 24-03-2009 07:51:57 PM
Thanks Brien!
Cisco Developer Community Forums wrote:
> Brien Williams has created a new message in the forum "General
> Discussion - All Versions":
> Â
> Â
> To respond to this post, please click the following link:
> <http://developer.cisco.com/web/cvp/forums/-/message_boards/message/1225156>
> or simply reply to this email.
