cdnadmin
Community Member
This document was generated from CDN thread
Created by: Kantha wijesekara on 18-06-2012 09:45:35 AM
When dialing to remote VCON using Edge 95 MXP , it prompts unreachable destination always. IP connectivity is used direct  global ip.Checked the connectivity from unit also OK.
What could be the problem
