Heads Up :
The post you are writing will appear in a public forum. Please ensure all content is appropriate for public consumption. Review the employee guidelines for the community here.
Subject: RE: New Message from Janine Graves in Customer Voice Portal (CVP) - CVP - A Replied by: Greg Worm on 29-11-2011 06:13:00 PM Yes the box is checked. This worked in 4.1 and now the audio objects are not populated.
From: Cisco Developer Community Forums [mailto:[email protected]] Sent: Tuesday, November 29, 2011 5:09 PM To: [email protected] Subject: New Message from Janine Graves in Customer Voice Portal (CVP) - CVP - All Versions: Re: New Message from Greg Worm in Customer Voice Portal (CVP) - CVP - All V
Janine Graves has created a new message in the forum "CVP - All Versions":
-------------------------------------------------------------- In Studio, in the General Tab, did you select the checkbox named Create Base Config? If not, the VoiceElementConfig variable will be null. On 11/29/2011 5:36 PM, Cisco Developer Community Forums wrote: After upgrading a customer from CVP 4.1 to CVP 6.0 we have noticed that the VoiceElementConfig variable of the getConfig method is always blank in our Dynamic Configuration java classes. The variable is not null but none of the audio objects are populated even though the audio items are defined through the tool. Has anyone ever seen this behavior? If so how did you resolve the issue? -- Janine Graves -- To respond to this post, please click the following link:
or simply reply to this email. This document was generated from CDN thread
Created by: Greg Worm on 29-11-2011 05:36:11 PM After upgrading a customer from CVP 4.1 to CVP 6.0 we have noticed that the VoiceElementConfig variable of the getConfig method is always blank in our Dynamic Configuration java classes. The variable is not null but none of the audio objects are populated even though the audio items are defined through the tool. Has anyone ever seen this behavior? If so how did you resolve the issue?
Subject: Re: New Message from Greg Worm in Customer Voice Portal (CVP) - CVP - All V Replied by: Janine Graves on 29-11-2011 06:09:00 PM In Studio, in the General Tab, did you select the checkbox named Create Base Config? If not, the VoiceElementConfig variable will be null. On 11/29/2011 5:36 PM, Cisco Developer Community Forums wrote: After upgrading a customer from CVP 4.1 to CVP 6.0 we have noticed that the VoiceElementConfig variable of the getConfig method is always blank in our Dynamic Configuration java classes. The variable is not null but none of the audio objects are populated even though the audio items are defined through the tool. Has anyone ever seen this behavior? If so how did you resolve the issue? -- Janine Graves
Subject: Re: New Message from Greg Worm in Customer Voice Portal (CVP) - CVP - All V Replied by: Janine Graves on 29-11-2011 06:27:00 PM Did you try importing the studio project into Studio and then doing the Deploy again - so it creates a runtime version that works for that vxml server? On 11/29/2011 6:13 PM, Cisco Developer Community Forums wrote: Greg Worm has created a new message in the forum "CVP - All Versions": -------------------------------------------------------------- Yes the box is checked. This worked in 4.1 and now the audio objects are not populated. From: Cisco Developer Community Forums [mailto:[email protected]] Sent: Tuesday, November 29, 2011 5:09 PM To: [email protected] Subject: New Message from Janine Graves in Customer Voice Portal (CVP) - CVP - All Versions: Re: New Message from Greg Worm in Customer Voice Portal (CVP) - CVP - All V Janine Graves has created a new message in the forum "CVP - All Versions": -------------------------------------------------------------- In Studio, in the General Tab, did you select the checkbox named Create Base Config? If not, the VoiceElementConfig variable will be null. On 11/29/2011 5:36 PM, Cisco Developer Community Forums wrote: After upgrading a customer from CVP 4.1 to CVP 6.0 we have noticed that the VoiceElementConfig variable of the getConfig method is always blank in our Dynamic Configuration java classes.ÿ The variable is not null but none of the audio objects are populated even though the audio items are defined through the tool.ÿ Has anyone ever seen this behavior?ÿ If so how did you resolve the issue? -- Janine Graves -- To respond to this post, please click the following link: <http://developer.cisco.com/web/cvp/forums/-/message_boards/view_message/4814288> or simply reply to this email. -- To respond to this post, please click the following link: <http://developer.cisco.com/web/cvp/forums/-/message_boards/view_message/4809951> or simply reply to this email. -- Janine Graves
Subject: RE: Empty Base Configuration Replied by: Hemal Mehta on 29-11-2011 10:19:32 PM What is the exact studio version that you are using ? I believe there was a bug fixed earlier that caused the getName method of VoiceElementConfig.AudioItem to always return null when accessed from a dynamic configuration Java class.
Subject: RE: Empty Base Configuration Replied by: Greg Worm on 30-11-2011 10:25:21 AM Cisco Unified Customer Voice Portal VXML Server v4.1(1)
and
Cisco Unified Call Studio Version: 6.0(1) Build id: 200711142043
Subject: RE: New Message from Greg Worm in Customer Voice Portal (CVP) - CVP - All V Replied by: Hemal Mehta on 30-11-2011 11:00:13 PM Just make sure with TAC that it is fixed in the one you have. I believe that there was a bug pertaining to this and was fixed in 6.0(1) Do you have release notes for this studio ? Hemal ________________________________ From: Cisco Developer Community Forums [[email protected]] Sent: Wednesday, November 30, 2011 9:25 AM To: [email protected] Subject: New Message from Greg Worm in Customer Voice Portal (CVP) - CVP - All Versions: RE: Empty Base Configuration
-------------------------------------------------------------- Cisco Unified Customer Voice Portal VXML Server v4.1(1)
and
Cisco Unified Call Studio Version: 6.0(1) Build id: 200711142043 -- To respond to this post, please click the following link:
Subject: RE: Empty Base Configuration Replied by: Greg Worm on 01-12-2011 09:58:21 AM I am not sure the null name is the issue. All of the audio groups are empty.
Subject: RE: Empty Base Configuration Replied by: Louise Tranter on 08-12-2011 11:06:49 AM Just wondering if there was ever a resolution to this issue? I am also experiencing a null initial_audio_group even when the check box is ticked and a is prompt configured. I am using Call Studio 8.5(0). Any further info would be much appreciated.
Subject: RE: New Message from Louise Tranter in Customer Voice Portal (CVP) - CVP - Replied by: Greg Worm on 08-12-2011 11:10:30 AM I have not found an answer. I have just configured all of the audio in the Java code.
From: Cisco Developer Community Forums [mailto:[email protected]] Sent: Thursday, December 08, 2011 10:07 AM To: [email protected] Subject: New Message from Louise Tranter in Customer Voice Portal (CVP) - CVP - All Versions: RE: Empty Base Configuration
Louise Tranter has created a new message in the forum "CVP - All Versions":
-------------------------------------------------------------- Just wondering if there was ever a resolution to this issue? I am also experiencing a null initial_audio_group even when the check box is ticked and a is prompt configured. I am using Call Studio 8.5(0). Any further info would be much appreciated. -- To respond to this post, please click the following link:
Subject: RE: New Message from Greg Worm in Customer Voice Portal (CVP) - CVP - All V Replied by: Louise Tranter on 08-12-2011 11:17:30 AM Ok - thanks for letting me know. If I find a solution I will post it. ________________________________ From: Cisco Developer Community Forums [[email protected]] Sent: 08 December 2011 16:10 To: [email protected] Subject: New Message from Greg Worm in Customer Voice Portal (CVP) - CVP - All Versions: RE: New Message from Louise Tranter in Customer Voice Portal (CVP) - CVP -
-------------------------------------------------------------- I have not found an answer. I have just configured all of the audio in the Java code.
Please consider the environment before printing this email.
The content of this email and any attachment is private and may be privileged. If you are not the intended recipient, any use, disclosure, copying or forwarding of this email and/or its attachments is unauthorised. If you have received this email in error please notify the sender by email and delete this message and any attachments immediately. Nothing in this email shall bind the Company or any of its subsidiaries or businesses in any contract or obligation, unless we have specifically agreed to be bound.
KCOM Group PLC is a public limited company incorporated in England and Wales, company number 02150618 and whose registered office is at 37 Carr Lane, Hull, HU1 3RE.
118288 - KCOM Group UK Directory Enquiries. Calls will cost no more than 99p connection + 49p per minute including VAT from a KC or BT landline. Call charges from mobiles and other networks may vary. If you are calling from a mobile you will now receive your requested number via text message. You will not be charged for the text message.
