cdnadmin
Community Member
This document was generated from CDN thread
Created by: Matthias Diehl on 07-05-2009 12:29:46 PM
Hello
I have a issue to add Translation Pattern to our Callmanager 6.1.1 with AXL SOAP Interface.
When i use the command addTransPattern i receive always a exception:
PatternUrgency is always TRUE for Translation Pattern
I change this PatternUrgency to true, false and leave out this Parameter. But i always get this exception.
Can anyone help me?
Matthias
Subject: RE: Error - addTransPattern - PatternUrgency is always TRUE
Replied by: julien CHODLEWSKI on 07-05-2009 01:07:37 PM
I had  this issue too .
I put the element "patternUrgency" between" "pattern" and "description", I set it to "true" and it was ok.
Try that !
Julien
Replied by: Matthias Diehl on 07-05-2009 01:21:59 PM
Hello
I added patternUrgency beetween pattern and description, but unfortunately this has not helped.
<addTransPattern>
   123
   true
   <description>test</description>
   <usage>Translation</usage>
   <routePartitionName>test</routePartitionName>
   <blockEnable>false</blockEnable>
   <calledPartyTransformationMask></calledPartyTransformationMask>
   <callingPartyTransformationMask></callingPartyTransformationMask>
   <callingPartyPrefixDigits>00</callingPartyPrefixDigits>
   <useCallingPartyPhoneMask>Off</useCallingPartyPhoneMask>
   <dialPlanWizardGenId></dialPlanWizardGenId>
   <digitDiscardInstructionName>PreDot</digitDiscardInstructionName>
   <messageWaiting>Lamp Off</messageWaiting>
   <networkLocation>OnNet</networkLocation>
   <callingSearchSpaceName>internal</callingSearchSpaceName>
 </addTransPattern>
Matthias
Replied by: julien CHODLEWSKI on 07-05-2009 01:52:26 PM
ok, but "prefixDigitsOut" is missing. This element have to be at the end after callingSearchSpaceName. It can be null, but it has to be here.
The exception is always the same ? "PatternUrgency is always TRUE for Translation Pattern"
Replied by: Matthias Diehl on 07-05-2009 02:03:59 PM
strange
i think this forum not shows all. i have added "prefixdigitOut" but the error is the same
(System.Web.Services.Protocols.SoapException: PatternUrgency is always TRUE for Translation Pattern
i attached a file with my addTransPattern request
Replied by: Matthias Diehl on 08-05-2009 02:09:05 PM
Hello Julien
Can you post your configuration from addTransPattern. Perhaps i found any differences.
Matthias
Replied by: julien CHODLEWSKI on 08-05-2009 03:19:48 PM
In fact I use php with soap extension, so I don't use hard-coded request. I give an array  to a function "__soapCall" and this one build the request.
Here is the code :
$newPattern=array('newPattern'=>array('pattern'=>'1234',
      'patternUrgency'=> 'true',
      'description' => 'test2',
      'usage'=>'Translation',
      'routePartitionName'=>'P_paris',
      'blockEnable'=>'false',
      'calledPartyTransformationMask'=> '0101010101',
      'callingPartyTransformationMask'=>'',
      'useCallingPartyPhoneMask' => 'Default',
      'dialPlanWizardGenId'=>'',
      'digitDiscardInstructionName'=>'PreDot',
      'messageWaiting'=>'Lamp Off',
      'networkLocation'=> 'OnNet',
      'callingSearchSpaceName'=>'',
      'prefixDigitsOut'=> ''));
$result=$client->__soapCall("addTransPattern",array('AddTransPatternReq'=>$newPattern));
and this code work well.
I don't understand why your request not work, yet i put the same attribute, I think.
Replied by: Matthias Diehl on 11-05-2009 11:06:17 AM
Which Callmanager Version do you use?
Replied by: julien CHODLEWSKI on 11-05-2009 01:46:17 PM
Hi Matthias,
I'm using the 6.0(1) and 6.1(2)
Replied by: ALFREDO PRADO on 14-11-2009 04:55:59 PM
I had  this issue too . I use the same code that Julien:
    'routePartitionName'=>'P_BAT_TEST1',
$result=$client->addTransPattern($newPattern);
but when see the logs in AXL Web service the SOAP request show the follow:
<SOAP-ENV:Envelope xmlns:SOAP-ENV="http://schemas.xmlsoap.org/soap/envelope/" xmlns:ns1="http://www.cisco.com/AXL/API/6.1">
<SOAP-ENV:Body><ns1:addTransPattern>
<newPattern><pattern>1234</pattern>
<description>test2</description>
<routePartitionName>P_BAT_TEST1</routePartitionName>
<blockEnable>true</blockEnable>
<calledPartyTransformationMask>0101010101</calledPartyTransformationMask>
<useCallingPartyPhoneMask>Default</useCallingPartyPhoneMask>
<callingSearchSpaceName></callingSearchSpaceName>
</newPattern>
</ns1:addTransPattern></SOAP-ENV:Body>
</SOAP-ENV:Envelope>
For any strange reason, the PHP SOAP function not send "patternUrgency" field.
I'm use Call Manager version 6.1.2.1000-13
Replied by: ALFREDO PRADO on 15-11-2009 02:00:24 PM
Hi:
   I'm investigate the problem and I see that PHP have problem with load AXLAPI.wsdl file, when I change the order some field in this file for example locationName in addPhone that is not recognize or send in SOAP request, when I change the order in definition, the request work. With this work in solution and found that problem is the version PHP, because I try the same code in follow PHP version:
Linux debian 2.6.26-1-686 #1 SMP Fri Mar 13 18:08:45 UTC 2009 i686 GNU/Linux
php -v
PHP 5.2.6-1+lenny3 with Suhosin-Patch 0.9.6.2 (cli) (built: Apr 26 2009 22:16:23)
Copyright (c) 1997-2008 The PHP Group
Zend Engine v2.2.0, Copyright (c) 1998-2008 Zend Technologies
The version of above all params from the array are send with SOAP function request. All work fine.
Linux odisea.n 2.6.16.38.xs3.2.0.531.3960 #2 SMP Sat Mar 24 22:03:09 UTC 2007 i686 GNU/Linux
 php -v
PHP 5.2.0-8+etch13 (cli) (built: Oct  2 2008 08:26:18)
Copyright (c) 1997-2006 The PHP Group
Zend Engine v2.2.0, Copyright (c) 1998-2006 Zend Technologies
The version of above not all params from the array are send with SOAP function request. For example:
   in addPhone ...... locationName, User Hold MOH Audio Source,Network Hold MOH Audio Source,etc not send with SOAP request.
   I hope help you with yours problem.
   Best Regards,
   Alfredo Prado
