This document was generated from CDN thread
Created by: Senthil Kumar on 11-08-2008 04:37:15 AM
I have developed a simple Web services application. In that application
when I click the 'Exit' soft button in the screen, it showing the previous page.
I want to completely exit from the application when the user click the 'Exit' soft button.
Here the code snippets for refernce:
<CiscoIPPhoneText>
<Title>Invalid Input</Title>
<Prompt>Please provide the user information</Prompt>
<Text>Invalid user Inputs!</Text>
<SoftKeyItem>
<Name>Back</Name>
<URL>SoftKey:Exit</URL>
<Position>1</Position>
</SoftKeyItem>
</CiscoIPPhoneText>
Thank you,
Senthil Kumar R
Subject: Re: Exit soft button issue
Replied by: David Staudt on 11-08-2008 02:50:46 PM
The phone keeps a cache of the last 10 URLs visited, and the Exit softkey navigates back through list (pages which are set to expire immediately are not saved in the cache.)
If you want to immediately close the Services plane, you can use the Init:Services URI.
<SoftKeyItem>
<Name>Back</Name>
<URL>Init:Services</URL>
Replied by: Senthil Kumar on 11-08-2008 04:52:42 PM
Thank you very much.
Senthil Kumar R
Replied by: Shameer AbdulRasheed on 09-09-2008 07:29:24 AM
Please ignore...Found that the answer is already provided by David.
Use the 'Init:Services' phone URI to clear the screen. ie., in the XML, instead of using 'Softkey:exit' use 'Init:Services'
Edited by: Shameer AbdulRasheed on Sep 9, 2008 3:29 AM
Subject: RE: soft button issue
Replied by: qiaohua liu on 30-09-2009 09:48:06 PM
I am new in IP Phone service, could u tell me how to add a new softkey on the phone 7961? thanks!
