cdnadmin
Community Member
This document was generated from CDN thread
Created by: Anders Westlund on 24-01-2012 06:23:34 AM
I'm devloping a script that does some "number2name." actitivies and fill in the name field using the "set callInfo(displayInfo) $MyText" command:
What I would like is a possibility to handle a script failure: I.e. if any incoming call hit the dialpeer that activates the script and the script, for some unknown reason, fails the call shall be setup on the same gateway but on a dialpeer without the script activated: This will allow the call to be setup even during a script failure.
Lets for example say that incoming number in the 3*** and 4*** range shal be handled by the script.
BR
Anders
Subject: RE: Fallback dialpeer on script failure
Replied by: Raghavendra Gutty Veeranagappa on 24-01-2012 12:06:55 PM
Hi Anders,
In case of script failures the call will cleared, i don't think it is possible to route the call to another dial peer.
Raghavendra
