This document was generated from CDN thread Created by: Chandar vr on 09-09-2009 03:59:10 PM Hi, I am getting following error whenever i try to access most of the api's from PHP. The Php code is 1
2 $client = new SoapClient(...........);
3 var_dump($client->getTransPattern(array('uuid'=>'xxxxxx-xxxx-xxxx-xxxx-xxxxxx'));
the error code is 1
3object(SoapFault)#105 (9) {
4 ["message:protected"]=>
5 string(51) "Item not valid: The specified Pattern was not found"
6 ["string:private"]=>
7 string(0) ""
8 ["code:protected"]=>
9 int(0)
10 ["file:protected"]=>
11 string(44) "/path/a.php"
12 ["line:protected"]=>
13 int(31)
14 ["trace:private"]=>
15 array(2) {
16 [0]=>
17 array(4) {
18 ["function"]=>
19 string(6) "__call"
20 ["class"]=>
21 string(10) "SoapClient"
22 ["type"]=>
23 string(2) "->"
24 ["args"]=>
25 array(2) {
26 [0]=>
27 string(15) "getTransPattern"
28 [1]=>
29 array(1) {
30 [0]=>
31 array(1) {
32 ["uuid"]=>
33 string(36) "xxxxxx-xxxx-xxxx-xxxx-xxxxxx"
34 }
35 }
36 }
37 }
38 [1]=>
39 array(6) {
40 ["file"]=>
41 string(44) "/path/a.php"
42 ["line"]=>
43 int(31)
44 ["function"]=>
45 string(15) "getTransPattern"
46 ["class"]=>
47 string(10) "SoapClient"
48 ["type"]=>
49 string(2) "->"
50 ["args"]=>
51 array(1) {
52 [0]=>
53 array(1) {
54 ["uuid"]=>
55 string(36) "xxxxxx-xxxx-xxxx-xxxx-xxxxxx"
56 }
57 }
58 }
59 }
60 ["faultstring"]=>
61 string(51) "Item not valid: The specified Pattern was not found"
62 ["faultcode"]=>
63 string(15) "SOAP-ENV:Client"
64 ["detail"]=>
65 object(stdClass)#103 (1) {
66 ["Error"]=>
67 object(stdClass)#104 (3) {
68 ["code"]=>
69 string(4) "5007"
70 ["message"]=>
71 string(51) "Item not valid: The specified Pattern was not found"
72 ["request"]=>
73 string(15) "getTransPattern"
74 }
75 }
76}
77
Subject: RE: Fault String .. Replied by: David Staudt on 09-09-2009 08:56:24 PMI think you may need to include the curly braces: '{34CB1D65-8938-F8A6-58D4-DC2BF0416542}'Subject: RE: Fault String .. Replied by: Chandar vr on 10-09-2009 07:14:58 AM Even i tried adding the curly braces still i coulldnt succeed ....Do i have to add some other parameter along with this .. Please advise me ....Subject: RE: Fault String .. Replied by: David Staudt on 10-09-2009 03:49:24 PMLooking at the AXL trace logging via the UCM's RTMT tool may be helpful, as it will display the actual XML message received/sent. It's possible SOAPClient is not constructing the XML message properly. Using SOAPui, the following XML worked fine for me: <soapenv:Envelope xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/" xmlns:ns="http://www.cisco.com/AXL/API/7.0"> <soapenv:Header/> <soapenv:Body> <ns:getTransPattern sequence="1"> <uuid>{E01F9C07-2C4F-2334-8507-A15D1585251C}</uuid> </ns:getTransPattern> </soapenv:Body></soapenv:Envelope> Note the case of the letters in the uuid is significant. It's also possible the uuid you are looking for simply doesn't exist...
