cdnadmin
Community Member
This document was generated from CDN thread
Created by: null on 23-08-2006 10:05:27 PM
I am using fetchaudio code given by audium , which sleeps for 10 sec in the helloworld applicaiton. The app has just Fetchaudio element. It is throwing error.semantic , after playing "Hold message" which code uses in the initial iteration.
I am using CVP3.1. Any help will be appreciated.
Ravi.
Subject: RE: Fetchaudio Element - error.semantic
Replied by: null on 24-08-2006 02:30:34 PM
Attached is the VXML broswer log.
Replied by: Vance Vagell on 28-08-2006 04:29:05 PM
Hi Ravi,
Which fetchaudio code are you referring to? Also, the voice browser log you mentioned does not seem to be attached to your reply. Please provide additional information about what you are trying to accomplish, and we would be glad to help you resolve this issue.
Vance
