cdnadmin
Community Member
This document was generated from CDN thread
Created by: Jawad Bokhari on 15-05-2012 07:18:55 AM
We have successfully installed Finesse in our lab environment.
We are trying to install the sample screenpop gadget provided but having serious java-script errors.
In fact, I cannot view the "Finesse Layout XML" tab properly. It opens in a squeezed box.
On firefox using a web-console, I managed to gather following error messages:
I get few lines of following error message after some successful POST messages:
Could not find a translation for en-US                                       concat...ings.js (line 1408)
Then, I get following error message:
<a>
</a>
uncaught
exception: Could not load cross-domain resources:
dojox.grid.DataGrid
dojo.data.ItemFileReadStore dijit._Widget dijit._Templated
dijit.form.Button dijit.form.SimpleTextarea dijit.form.CheckBox
dojox.data.XmlStore dojo.parser dojo.data.util.simpleFetch
dojo.data.util.filter dojox.xml.parser dojox.xml.DomParser
ciscowidgets.SignoutReasonCodeTable
<a>parse</a>()shindi...debug=1 (line 987)
str = "postmessage.test"
<a>onmessage</a>()shindi...debug=1 (line 1508)
packet = <a>message </a>
<a>
<pre class="errorSourceCode " title="return window.JSON.parse(str);">return window.JSON.parse(str);</pre>
</a><a>
</a>
uncaught exception: Could not load cross-domain resources: dijit.form.Button dijit.form.TextBox
followed by these error messages:
uncaught
exception: Could not load cross-domain resources: dojox.grid.DataGrid
uncaught
ciscowidgets.ReasonCodeTable dojo.data.util.simpleFetch
dojo.data.util.filter dojox.xml.parser dojox.data.XmlStore
dojox.xml.DomParser
uncaught exception: Could not load cross-domain resources: dijit.form.Button dijit.form.TextBox dijit.form.Select
15:54:49:
ERROR - url: , lineNumber: 0, msg: uncaught exception: Could not load
cross-domain resources: dijit.form.Button dijit.form.Textarea <a>
Log.js (line 104)
</a>
uncaught exception: Could not load cross-domain resources: dijit.form.Button dijit.form.Textarea
Did I miss something during installation or anything to be done post-install for any addtional mandatory configurations.
Thanks for  assistance
Subject: RE: Finesse Layout XML Problem - cannot modify
Replied by: David Lender on 14-06-2012 02:02:49 PM
Make sure you are using IE8 or later and that you are using http not https
