If you are using the Cisco Gateway with DTMF only, then you can only get
back the touch-tones entered from the caller within the Form element.
However, if you're using one of the other Gateways - like Nuance, OSR,
or another recognizer, then you will be able to get back the value
within the square brackets.
Janine
On 7/22/2010 12:26 PM, Cisco Developer Community Forums wrote:
> Raymond Lynn has created a new message in the forum "General
> Discussion - All Versions":
> I've got a Form element and I am trying to get it to return the
> optional value rather than the DTMF keypress.
> Â
> I have got the DTMF keypresses configured as
> Â
> 1
> 2
> 3
> Â
> When I run the application using the debugger it works fine but when
> it is deployed the value returned by the form element is always the
> key that was pressed and not the optional value.
> Â
> Am I doing something wrong?
> To respond to this post, please click the following link:
> <http://developer.cisco.com/web/cvp/forums/-/message_boards/message/2376910>>
> or simply reply to this email.
Janine Graves
781-990-1040
