cdnadmin
Community Member
This document was generated from CDN thread
Created by: Lee Heath on 04-05-2011 03:23:14 PM
Hello, Does anyone one know if it's possible to link a generic 1080p camera with HDMI output to a C20 codec?
Subject: RE: Generic Camera to C20 codec
Replied by: Roger Boe on 06-05-2011 01:14:19 PM
Hi Lee,
Yes, the HDMI input will accept any compatible video format. If the camera is either 1080p30 or 1080p60 this should work fine. However you will not be able to control the camera from the remote control of the codec.
Best regards
Roger
