cdnadmin
Community Member
This document was generated from CDN thread
Created by: Jan Seynaeve on 16-07-2013 03:22:23 AM
Hello all,
probably an easy one, but i just can't figure out how to get only the device profiles out of the device table. Am i missing a field here or is it realy not that trivial?
(I'm looking for something like select * from device where ???)
Thx already,
Jan.
Subject: RE: Get Device Profiles in SQL
Replied by: David Staudt on 16-07-2013 04:26:30 PM
Perhaps the device.tkdeviceprofile field is what you are looking for?
 1admin:run sql select * from typedeviceprofile
 2enum moniker                              name
 3==== ==================================== =======================
 42    DEVICE_PROFILE_AUTOGENERATED_PROFILE Autogenerated Profile
 51    DEVICE_PROFILE_USER_PROFILE          User Profile
 60    DEVICE_PROFILE_REAL_DEVICE           Real Device
 73    DEVICE_PROFILE_MODEL                 Model Profile
 84    DEVICE_PROFILE_USER_TEMPLATE         User Template Profile
 95    DEVICE_PROFILE_SYSTEM_TEMPLATE       System Template Profile
