cdnadmin
Community Member
This document was generated from CDN thread
Created by: Hoang Anh Tran on 05-10-2013 06:02:20 AM
Dear all,
I am new to AXL developing, I have read the tutorial: How to ... Create an AXL Java Client using JAX-WS at http://developer.cisco.com/web/axl-developer/axl-java-sample-application
I
 did import CUCM server certificate (self-signed) to Java keystore as instructed, add alias with IP address of the server.
Server is running at https://172.16.3.143:8443/axl/ . with CUCM v9
The code I am trying to run is extracted from sample code of the tutorial, and modified a bit to display in a GUI Text Area
It always throw exception at line: GetPhoneRes getPhoneResponse = axlPort.getPhone(axlParams);
 1[size=1]// Instantiate the wsimport generated AXL API Service client --
 2// see the wsimport comments in the class javadocs above
 3AXLAPIService axlService = new AXLAPIService();
 4AXLPort axlPort = axlService.getAXLPort();
 7// Set the URL, user, and password on the JAX-WS client
 8String validatorUrl = "https://172.16.3.143:8443/axl/";
 9
11((BindingProvider) axlPort).getRequestContext().put(BindingProvider.ENDPOINT_ADDRESS_PROPERTY, validatorUrl);
12((BindingProvider) axlPort).getRequestContext().put(BindingProvider.USERNAME_PROPERTY, "admin");
13((BindingProvider) axlPort).getRequestContext().put(BindingProvider.PASSWORD_PROPERTY, "P@ssW0rd");
14
15// Create a GetPhoneReq object to represent the getPhone request and set the name of the device
16//to name entered by user
17GetPhoneReq axlParams = new GetPhoneReq();
18axlParams.setName("SEPF02929E3CFB9");
19
20//Make a call to the AXL Service and pass the getPhone request
21[color=#ff0000]GetPhoneRes getPhoneResponse = axlPort.getPhone(axlParams);[/color]
22
23//display information returned in the response to the user
24this.jtaOutput.setText("Product=" + getPhoneResponse.getReturn().getPhone().getProduct() + "%n"+ getPhoneResponse.getReturn().getPhone().getLoadInformation().getValue() + "%n");[/size]
And the error message I am having is copied in attached txt file
Please help me out, I really need to pass this starting point. Thank you very much
Subject: RE: Help running Java sample AXL code? stuck at CertificateException
Replied by: Maic Naatz on 28-11-2013 06:40:38 AM
hi,
i am a newbee with java and have the same problem. I am trying to run the example from http://developer.cisco.com/web/axl-developer/axl-java-sample-application with the same error stored in error.txt above. Only difference, my operating system is Windows 7 and my imported certificate has the hostname from CUCM as alias. I imported that into my private keystore (C:\Users\\.keystore) and also into the cacerts file from corresponding java version (1.6.0_45). Maybe one of them is enough. I do not modify the demo.java file. Finally i compiled the Demo class to an jar-file (Demo.jar) to run it from windows command line with java -jar [Path to file]\Demo.jar. Is there an other possibility to start the example without compiling available?
Additionally there is a problem after importing the wsdl-file with wsimport tool (i use  Java 1.6.0_45 witch is different from 1.7.0_45). Some of the AXL-request have an red cross at the icon.
My import command was:
"C:\Program Files (x86)\Java\jdk1.6.0_45\bin\wsimport.exe" -keep -b schema/current/AXLSOAP.xsd -Xnocompile -s src -d bin -verbose schema/current/AXLAPI.wsdl
After the imort it seems to be okay. But waiting a little bit, the crosses accur. The schema was downloaded from my CUCM within the AXL toolkit.zip.
I am very grateful for an more detailed description to start with axl in java.
