Heads Up :
The post you are writing will appear in a public forum. Please ensure all content is appropriate for public consumption. Review the employee guidelines for the community here.
Created by: null on 14-03-2005 10:53:50 PM Where can I find a sample of code to execute during a hot-event? I want to log some data whenever I reach this particular event but recover back in the call flow (with a possible audio message indicating the feature isn't currently available.) Is there a place I can look for a template bit of code for hot-event processing?
Subject: RE: HotEvent code Replied by: Michael Bochynski on 17-03-2005 11:20:14 PM Hi Fred,
Your custom class for HotEvent would have to implement [b:24cb83e39b]HoteventInterface[/b:24cb83e39b] interface with a single method [i:24cb83e39b]addEventBody()[/i:24cb83e39b]
Note, however, that HotEvent code will be added to the root document and created in advance. Thus, you would have a generic message saying that the particular option is not available. You can also use VoiceXML log tag to log this event.
Note that noMatch and noInput will not trigger HotEvent code, since those events are being caught locally by an element.
Hope this helps, Michael
Subject: I didn't see any sample code for this Replied by: null on 17-03-2005 11:24:02 PM Can you point me to a piece of sample code?
Subject: RE: I didn't see any sample code for this Replied by: Michael Bochynski on 17-03-2005 11:27:24 PM Hi,
