Greeshma Bernad
For Cisco Unity Connection 8.x, perform these steps to Bulk Edit Send Message Setting to Dial By Extension for a no: of Users.
  1. In Cisco Unity Connection Administration, expand Tools, and then click Bulk Edit Utility.
  2. In the Bulk Edit utility, select the user accounts that you want to edit.
  3. Click Next
  4. Click the Message Send tab.
  5. For the Address Messages to Other Users By, you can select the option extension from the drop down menu.
  6. Click Next, and then click Finish.
Also refer Setting Up Features and Functionality That Are Controlled by User  Account Settings.
