cdnadmin
Level 11
Level 11
This document was generated from CDN thread
Created by: Eric Webb on 14-01-2013 04:27:02 PM
I am new to development/automation with UC.   I would like to programmatically update a forwarding number tied to a UC device using a web services call.   Today, as a user, I am accessing the "Cisco Unified CM User Options" page (http://servername:8443/ccmuser/showHome.do) on our 6.1.5 environment.   I go to User Options -> Device (a CTI Route Point) -> Line Settings and update the number that calls are being forwarded to.  The URL that seems to do the work is "/ccmuser/lineSettingsSave.do".
Is there a web services API that I can use to accomplish this via automation?
Subject: RE: How to change forward number for a device?
Replied by: David Staudt on 15-01-2013 11:00:01 AM
The AXL SOAP API is designed for this type of configuration/provisioning use-case: http://developer.cisco.com/web/axl-developer/home
