cdnadmin
Level 11
Level 11
This document was generated from CDN thread
Created by: Benjamin Isak on 09-10-2009 02:40:51 PM
dows anybody know how to put "read out data" (for example lamp-hours of a projector) from a crestron control system to an extern database like MySQL or any other DB in an easy way with SIMPL+ ?
For an explanation:
The Data is read out from a connected projector and programmatically stored in a string-variable. Now I want to send this value to an database!
Thanks in advance
Benjamin
Subject: RE: How to get data from a control system to an DB (e.g. mysql)
Replied by: David Bruun-Lie on 20-10-2009 09:17:06 AM
Hi Benjamin,
I think your question is more appropriate in a general Crestron forum. This forum is for specific Crestron integration with TANDBERG equipment :-)
David
