on 01-24-2014 01:34 PM
I'm new to CISCO tool development. I have a requirement to handle specific event. When the "Answer" button is clicked, I need to read the value in the variable 2, means any variable value I should be able to read. How do I write a event handler or do I get CTIOS code and I need to modify the code to handle the event, I don't know really. I need some help in this regards.
I'm a .NET developer with VC++ background. Can I use one of these languages to
achieve this or do I need to write programs in Java only.
My next question is do I get the source code for CTIOS or I need to use the
libraries available for CTIOS, refer those libraries and use the APIs you
mentioned. Right now in our work environment we are simply using the CTIOS
client and ICM interacts with the CTIOS to set the values. How do my program
interacts with the CTIOS to read the values. Sorry for these questions as I'm
completely new to this environment. If my program has to run at the CTIOS which
is client, what ever the program I write it needs to be installed in more than
500 client machines which is a big hassle, is there any way to avoid. Thanks in
advance.
