cdnadmin
Community Member
This document was generated from CDN thread
Created by: sujit pillai on 22-07-2010 08:02:41 AM
<CiscoIPPhoneInput>
<Title>Test</Title>
<Prompt></Prompt>
<URL>http://<%=HomeDir%>/addres.asp</URL>
<InputItem>
  <DisplayName>Name</DisplayName>
  <QueryStringParam>txtuser</QueryStringParam>
  <DefaultValue></DefaultValue>
  <InputFlags>A</InputFlags>
</InputItem>
<InputItem>
  <DisplayName>Phone</DisplayName>
  <QueryStringParam>txtphone</QueryStringParam>
  <InputFlags>N</InputFlags>
</InputItem>
<SoftKeyItem>
  <Name>Back</Name>
  <URL>http://<%=HomeDir%>/menu.asp</URL>
  <Position>1</Position>
</SoftKeyItem>
<SoftKeyItem>
  <Name>Add</Name>
  <URL>SoftKey:Submit</URL>
  <Position>2</Position>
</SoftKeyItem>
<SoftKeyItem>
  <Name>Search</Name>
  <URL>QueryStringParam:search=1</URL>
  <Position>3</Position>
</SoftKeyItem>
</CiscoIPPhoneInput>
when i press Add key i get querystringparameter txtuser and txtphone on addres.asp page but it is not work with
Search key.
How to pass the QueryStringParam search=1 along with the InputItem txtuser and txtphone to the addres.asp page when Search key is press?
thanks in advance.
Subject: RE: How to send QueryStringParam with SoftKey:Submit
Replied by: Imran Mamdani on 12-08-2010 03:48:39 PM
I dont think you can pass parameters using softkeys - it has to be a querystringparam. Thats what i think.
<CiscoIPPhoneInput>
<Title>Test</Title>
<Prompt></Prompt>
<InputItem>
</InputItem>
<InputItem>
</InputItem>
<SoftKeyItem>
<Name>Back</Name>
</SoftKeyItem>
<SoftKeyItem>
<Name>Add</Name>
</SoftKeyItem>
<SoftKeyItem>
<Name>Search</Name>
</SoftKeyItem>
Search key.
thanks in advance.
Replied by: Cindy Brozyno on 01-02-2012 07:13:55 AM
Not sure if this string is still relevant; however, in order to add that to the items passed, you should add it to the end of the url - ie.  /address.asp?search=1  The other input items will attach themselves automatically to the end.
Replied by: Cindy Brozyno on 02-02-2012 07:15:48 AM
When using a softkey, instead of <URL>Softkey:Submit</URL>, do something like this - <URL>http://xxx/xxx.asp?search=1 </URL> (the url of the next page). Then the actual input parameters will attach themselves automatically.  I have done this successfully in my service.
Cindy
