cdnadmin
Community Member
This document was generated from CDN thread
Created by: Tomas Ussher on 19-01-2011 12:48:54 PM
I had noticed this problem already long time ago but I was hoping it would get fixed in subsequent releases.
However it still exists in 15.0(1)M4. It causes a serious issue, preventing us from completing an application (We are Cisco Registered Developer).
The problem is that when -query is used with 'httpios geturl', custom headers are NOT sent to the server. This prevents from using POST and Authorization, that is indispensable for our application to work. I have not found any evidence indicating that one can not set custom headers in TCL http POST.
Test code:
proc act_Setup {} {
 set query {Test Body}
 set hdr {Authorization {Basic uuuuu:pppp} Custom XXX}
 set url http://10.0.1.128:8000/post.cgi
 ::httpios::geturl $url -headers $hdr -command httpCallback -query $query
proc httpCallback {token} {
 puts -nonewline "Status: [::httpios::status $token]"
 ::httpios::cleanup $token
 call close
package require httpios 1.0
set fsm(INIT,ev_handoff) "act_Setup same_state"
fsm define fsm INIT
Debug output:
Jan 19 18:36:39.704 CET: //4256//PACK:/tcl_httpiosGeturlObjCmd:  ::httpios::geturl http://10.0.1.128:8000/post.cgi -headers Authorization {Basic uuuuu:pppp} Custom XXX -command httpCallback -query Test Body
Jan 19 18:36:39.708 CET: //4256//PACK:/tcl_httpiosGeturlObjCmd: Current NS: ::
Jan 19 18:36:39.708 CET: //4256//PACK:/tcl_httpiosGeturlObjCmd: URL: http://10.0.1.128:8000/post.cgi
Jan 19 18:36:39.708 CET: //-1//PACK:/httpios_get_custom_headers: No Of Headers: 4
Jan 19 18:36:39.708 CET: //-1//PACK:/httpios_get_custom_headers: Authorization: Basic uuuuu:pppp
Custom: XXX
Received by server:
POST /post.cgi HTTP/1.1
Host: 10.0.1.128:8000
Content-Length: 9
Content-Type: application/x-www-form-urlencoded
Connection: close
Accept: text/vxml, text/x-vxml, application/vxml, application/x-vxml, application/voicexml, application/x-voicexml, text/plain, text/html, audio/basic, audio/wav, multipart/form-data, application/octet-stream
User-Agent: Cisco-IOS-C2801/15.0
Test Body
Again, when using GET operation, there is no problem and custom header are correctly sent, allowing authorization to work.
Subject: RE: httpios geturl does not send header for POST
Replied by: JAMES DEPHILLIP II on 28-08-2012 07:39:40 PM
I noticed this same issue on a VG over a year ago however I only noticed it while doing a HTTP POST. Is this still an issue or has this been resolved?
Test code:
proc act_Setup {} {
 call close
fsm define fsm INIT
Debug output:
Custom: XXX
Received by server:
Content-Length: 9
Connection: close
Test Body
Replied by: Tomas Ussher on 29-08-2012 12:31:13 PM
if you don't use -query with 'httpios geturl', will you able to send customer headers.
Excuse me, and how one would be supposed to do POST without using -query ?
From http TCL manual:
This flag causes ::http::geturl to do a POST request that passes the query to the server. The query must be an x-url-encoding formatted query. The::http::formatQuery procedure can be used to do the formatting.
Again, the question is:
Using POST method with httpio AND Basic authentication appears not to be possible
Replied by: Raghavendra Gutty Veeranagappa on 29-08-2012 08:49:45 AM
Raghavendra
