cdnadmin
Community Member
Subject: RE: httpios::geturl issue
Replied by: Raghavendra Gutty Veeranagappa on 21-12-2011 07:57:43 AM
Hi Marco,
please move your http code from init procedure to act_GetHTTP procedure, you can only do initialization inside init procedure.
Raghavendra
This document was generated from CDN thread
Created by: Marco Ziglioli on 21-12-2011 06:32:02 AM
Hi all,
I'm experiencing an issue with the httpios::geturl method.
Each
time I call this method seems it's not able to complete, the callback
method is not called at all and I obtained a couple of traceback error
messages that, i figured out, are telling me that something with the
memory went wrong.
I constructed a simple script, just
to troubleshoot the issue, that don't anything, just download an URL
and display it each time is loaded in the router. Here the code:
proc init { } {
     #global token
     set event [infotag get evt_event]
    log "Service Successfully Loaded !!! $event"
    #httpios::config -accept "text/plain"
    set url "http://10.254.147.69/test.php"
    puts "Before httpios::geturl"
    httpios::geturl "$url" -command act_RequestResult -timeout 1
    puts "After httpios::geturl"
proc act_RequestResult {token} {
    #global token
    set res [http::data $token]
    puts "Capture Result: $res"
proc act_Cleanup { } {
    set evt_name [infotag get evt_event]
    call close
package require httpios 1.0
init
#   State Machine
set TopFSM(any_state,ev_disconnected)         "act_Cleanup, same_state"
set TopFSM(any_state,ev_destroy_done)         "act_Cleanup, same_state"
set TopFSM(CALL_INIT,ev_handoff)    "act_GetHTTP, GETTINGHTTP"
set TopFSM(any_state,ev_any_event) "act_LogState, same_state"
fsm define TopFSM CALL_INIT
Here's the log collected from the IOS: an advanced ip services 12.4(24)T6 on a ISR 2811.
#call appl voice load testurl
000897: *Dec 21 12:27:19.220: %AAA-3-BADSERVERTYPEERROR: Cannot process accounting server type tacacs+ (UNKNOWN)
000898: *Dec 21 12:27:19.244: //-1//HIFS:/hifs_ifs_cb: hifs ifs file
read succeeded. size=955, url=tftp://10.254.147.69/testurl.tcl
000899: *Dec 21 12:27:19.248: //-1//HIFS:/hifs_free_idata: hifs_free_idata: 0x489E0A18
000900: *Dec 21 12:27:19.248: //-1//HIFS:/hifs_hold_idata: hifs_hold_idata: 0x489E0A18
000901: *Dec 21 12:27:19.248: //-1//AFW_:EE48B8C9E4000:/Tcl_Link: Linking script testurl
000902: *Dec 21 12:27:19.256: //-1//PACK:EE48B8C9E4000:/tcl_packageObjCmd:  package require httpios 1.0
000903: *Dec 21 12:27:19.256: //-1//TCL :EE48B8C9E4000:/tcl_InfotagObjCmd:  infotag get evt_event
000904: *Dec 21 12:27:19.256: //-1//TCL :EE48B8C9E4000:/tcl_InfotagGetObjCmd: infotag get evt_event
000905: *Dec 21 12:27:19.256: //-1//AFW_:EE48B8C9E4000:/vtr_ev_event: argc 2
000906: *Dec 21 12:27:19.264: //-1//AFW_:EE48B8C9E4000:/vtr_ev_event: Event [ev_any_event]
000907: *Dec 21 12:27:19.264: //-1//TCL :EE48B8C9E4000:/tcl_LogObjCmd: log Service Successfully Loaded !!! ev_any_event
000908: *Dec 21 12:27:19.264: %IVR-3-APP_ERR: Service Successfully Loaded !!! ev_any_event
000909: *Dec 21 12:27:19.264: //-1//TCL :EE48B8C9E4000:/tcl_PutsObjCmd: Before httpios::geturl
000910: *Dec 21 12:27:19.264:
000911: *Dec 21 12:27:19.264:
//-1//PACK:EE48B8C9E4000:/tcl_httpiosGeturlObjCmd:  httpios::geturl
http://10.254.147.69/test.php -command act_RequestResult -timeout 1
000912: *Dec 21 12:27:19.268: //-1//PACK:EE48B8C9E4000:/tcl_httpiosGeturlObjCmd: Current NS: ::
000913: *Dec 21 12:27:19.268: //-1//PACK:EE48B8C9E4000:/tcl_httpiosGeturlObjCmd: URL: http://10.254.147.69/test.php
000914: *Dec 21 12:27:19.268: //-1//TCL :EE48B8C9E4000:/tcl_PutsObjCmd: After httpios::geturl
000915: *Dec 21 12:27:19.268:
000916: *Dec 21 12:27:19.268: //-1//TCL :EE48B8C9E4000:/tcl_FSMObjCmd:  fsm define TopFSM CALL_INIT
000917: *Dec 21 12:27:19.268: //-1//TCL :EE48B8C9E4000:/tcl_FSMDefineObjCmd: State Machine: Array TopFSM: Start State: CALL_INIT
000918: *Dec 21 12:27:19.268: //-1//TCL :EE48B8C9E4000:/tcl_FSMDefineObjCmd: FSM Data structure
000919: *Dec 21 12:27:19.268: (any_state(0), ev_destroy_done(37)--(act_Cleanup)-->(any_state(0))
000920: *Dec 21 12:27:19.268: (any_state(0), ev_disconnected(18)--(act_Cleanup)-->(any_state(0))
000921: *Dec 21 12:27:19.268: (any_state(0), ev_any_event(0)--(act_LogState)-->(any_state(0))
000922: *Dec 21 12:27:19.268: (CALL_INIT(1), ev_handoff(22)--(act_GetHTTP)-->(GETTINGHTTP(2))
000923: *Dec 21 12:27:19.268: FSM start state CALL_INIT(1)
000924: *Dec 21 12:27:19.268: //-1//AFW_:EE48B8C9E4000:/Tcl_Link: Script testurl succesfully linked.
000925: *Dec 21 12:27:19.280: //-1//PACK:/httpios_http_get_cb:
000926: *Dec 21 12:27:19.280: httpios_http_get_cb: status: 200
000927: *Dec 21 12:27:19.280: //-1//AFW_:/AFW_Instance_CheckType: 0:
NULL object -Traceback= 0x424097D0z 0x42416074z 0x424CE6F8z 0x41FDF854z
0x41FE5608z 0x41FE640Cz 0x41FE70DCz 0x4321A5B4z 0x4321A598z
000928: *Dec 21 12:27:19.284: %SCHED-7-WATCH: Attempt to enqueue
uninitialized watched queue (address 0). -Process= "http client
process", ipl= 0, pid= 235,  -Traceback= 0x4322E148z 0x424CE6F8z
0x41FDF854z 0x41FE5608z 0x41FE640Cz 0x41FE70DCz 0x4321A5B4z 0x4321A598z
As
you can see the callback method has not been called because in all the
trace I haven't the "Capture Result" message that should be shown by the
act_RequestResult method.
Here I also provide
the debug collected from the IOS for the http client system (debug http
client msg and debug http client error):
000930: *Dec 21 12:30:38.925: //-1//HIFS:/hifs_ifs_cb: hifs ifs file
000931: *Dec 21 12:30:38.929: //-1//HIFS:/hifs_free_idata: hifs_free_idata: 0x489E0984
000932: *Dec 21 12:30:38.929: //-1//HIFS:/hifs_hold_idata: hifs_hold_idata: 0x489E0984
000933: *Dec 21 12:30:38.941: %IVR-3-APP_ERR: Service Successfully Loaded !!! ev_any_event
000934: *Dec 21 12:30:38.953: //0//HTTPC:/httpc_write_stream: Client write buffer fd(0):
GET /test.php HTTP/1.1
Host: 10.254.147.69
Content-Type: application/x-www-form-urlencoded
Connection: Keep-Alive
Accept: text/vxml, text/x-vxml, application/vxml, application/x-vxml,
application/voicexml, application/x-voicexml, text/plain, text/html,
audio/basic, audio/wav, multipart/form-data, application/octet-stream
User-Agent: Cisco-IOS-C2800NM/12.4
000935: *Dec 21 12:30:38.953: //0//HTTPC:/httpc_msg_read: Start processing 261 bytes data
000936: *Dec 21 12:30:38.957: //0//HTTPC:/httpc_msg_read: Ignored -
failed to decode message header (Server: Apache/2.2.20 (Ubuntu)) for
(msg(49E2CA9C)
000937: *Dec 21 12:30:38.957: //0//HTTPC:/httpc_msg_read: Ignored -
failed to decode message header (X-Powered-By: PHP/5.3.6-13ubuntu3.3)
for (msg(49E2CA9C)
000938: *Dec 21 12:30:38.957: //0//HTTPC:/httpc_msg_read: Ignored -
failed to decode message header (Vary: Accept-Encoding) for
(msg(49E2CA9C)
000939: *Dec 21 12:30:38.957: //0//HTTPC:/httpc_msg_read: Stored header at 0x48B7270C, len=249 stored
000940: *Dec 21 12:30:38.957: //0//HTTPC:/httpc_msg_read: Stored msg. body: len=12
000941: *Dec 21 12:30:38.957: processing server rsp msg: msg(49E2CA9C)URL:http://10.254.147.69/test.php, fd(0):
000942: *Dec 21 12:30:38.957: Request msg: GET /test.php HTTP/1.1
000943: *Dec 21 12:30:38.957: Message Response Code: 200
000944: *Dec 21 12:30:38.957: Message Rsp Decoded Headers:
000945: *Dec 21 12:30:38.957: Date:Wed, 21 Dec 2011 11:17:02 GMT
000946: *Dec 21 12:30:38.957: Content-Length:12
000947: *Dec 21 12:30:38.957: Content-Type:text/html
000948: *Dec 21 12:30:38.957: Connection:Keep-Alive
000949: *Dec 21 12:30:38.957: Keep-Alive:timeout=5, max=100
000950: *Dec 21 12:30:38.957: headers:
000951: *Dec 21 12:30:38.957: HTTP/1.1 200 OK
Date: Wed, 21 Dec 2011 11:17:02 GMT
Content-Length: 12
Keep-Alive: timeout=5, max=100
Content-Type: text/html
000952: *Dec 21 12:30:38.961: body:
000953: *Dec 21 12:30:38.961: 1
000954: *Dec 21 12:30:38.961:
000955: *Dec 21 12:30:38.961: %SCHED-7-WATCH: Attempt to enqueue
As you can see the page (that is a simple text file containing numbers from 1 to 6) is correctly downloaded.
Thanks in advance for any help.
Marco
Replied by: Anusha Kannappan on 21-12-2011 07:17:58 AM
Hi Marco,
From the debug logs provided we see there errors thrown as following
Please check whether there are any mis-configurations of tacacs server.
Anusha
Replied by: Marco Ziglioli on 21-12-2011 10:03:11 AM
Hi Marco,
Raghavendra
You're totally right.
Now that I moved the geturl outside the init everything work fine.
Thanks a lot.
Marco
Replied by: Marco Ziglioli on 21-12-2011 10:05:25 AM
Hi Marco,
Anusha
You're right but I'm in a bank and they cannot subscribe me to their directory system so they temporarly removed the TACACS just to let me work without gimme an account.
Anyway thank you for your hint.
Marco
