cdnadmin
Community Member
This document was generated from CDN thread
Created by: Vijay Jayaraman on 28-10-2008 05:28:17 PM
We have business application designed in such a way that ICM & CVP are tightly coupled, ICM acts as the controller, while CVP is the IVR flow. The ICM scripts use "Run Ext.Script" node to call the CVP app, and in the CVP app we use the Subdialog_Start and Subdialog_Return elements for the entry and exit respectively. To put it simple, ICM invokes APP1 and returns back, again invokes APP2 and return back, again invokes APP3 and returns back and finally returns the ROUTE-LABEL to PG.
Now we have a requirement, such that ICM invokes a particular CVP app, which in turn should do a application transfer to another CVP app and the second app should be able to return back to the ICM, ie, ICM invokes APP1, which does a application transfer to APP2, and it should return back to ICM, Is this feasible, if so, should I've to use Subdialog_start in the 2^nd^ CVP app.
Any quick response would be greatly appreciated.
thanks,
Vijay
Subject: Re: ICM - CVP Interface
Replied by: Mert Guray on 02-11-2008 08:52:39 PM
Hi Vijay,
I think it shouldn't be a problem to do like this.
-ICM calls APP1
-APP1 calls APP2
-APP2 reurns to APP1 (you want it to return to ICM)
  • APP1 returns to ICM as soon as it returns from APP2.
I don't think that you can directly return from APP2.
Replied by: Janine Graves on 03-11-2008 12:07:07 AM
If you are talking about Studio App1 using the Application Transfer element to transfer control to another Studio Application, App2, then yes, you are right.
When App2 executes its Subdialog_Return (note, in v7.0, it's now called CVP_Subdialog_Return) then it DOES INDEED return back to ICM.
Note, If you are talking about Studio App1 using the Subdialog_Invoke (v7.0) element to invoke App2 as a subdialog, then things are a bit different.
Janine
