This document was generated from CDN thread
Created by: Angelina Talley on 25-08-2011 11:11:14 PM
Hi folks. Sorry if this isn't the right place to post - I couldn't find anyplace better.
I'm seeing something unusual in my outbound ICM script that I wanted to get some opinions on.
This is the setup:
version 8.5
direct preview campaign
agent only campaign (no IVR)
We've got a very simple ICM script that selects the longest avaiailable agent to present them with the next dialer record to accept. As I understand it, the dialer won't even attempt to offer the record to an agent unless there is at least one agent available. In the ICM script, there is a Select LAA node before the Skill Group node used to select the actual agent. We're seeing about 25% of the calls failing out the X at the LAA node. What could cause this node to fail? It's been suggested that it's because the agent went unavailable again during the time it took to get the record up, but with only 5 agents running 100% outbound, that seems unusual. Any other ideas on why this could be failing out of the LAA node?
Thanks!
