This document was generated from CDN thread
Created by: Janine Graves on 07-12-2007 10:24:13 PM
Is there a reason that you don't return the value of the inputmode shadow variable to the Studio app? It's pretty important when allowing both speech and dtmf to know how the caller entered the data.
While it would seem that a confidence level of 1.0 would indicate DTMF entry, I have seen 1.0 occasionally returned for a speech utterance, so looking only at the confidence is not enough of an indication.
Any suggestions?
Subject: RE: inputmode shadow variable
Replied by: null on 10-12-2007 05:01:53 PM
I thought that using elements, speech or DTMF you get back inputtype as a value usually. I'm sure i saw it recently when i was doing a load of nbest work around these objects.
Replied by: Janine Graves on 12-12-2007 01:28:11 AM
You're right, now that I look at the logs, I see that the Form element returns the inputmode.
But, none of the other voice elements return an inputmode.
Thanks for pointing it out.
Janine
