Heads Up :
The post you are writing will appear in a public forum. Please ensure all content is appropriate for public consumption. Review the employee guidelines for the community here.
Created by: Peter Depalma on 14-05-2009 03:30:55 PM Hello, Was wondering if there is any way to insert a delay in VXML. I don't want to insert silent wav files, nor do I want to use microapps. What I really needs is a delay element that could accept a numeric value as a session variable I could pass from ICM...that way it can be easily and quickly tweaked from the ICM script. Any ideas, or anyone want to share an element they already have?
Subject: Re: New Message from Peter Depalma in Customer Voice Portal (CVP) - General Replied by: Janine Graves on 14-05-2009 03:40:00 PM are you saying that you want to insert a 'sleep' in the studio application or do you want to play a pause to the caller? If you want to insert a 'sleep' into the studio app, you could easily create a Java element to do that. It's a 1-liner in Java. If you create it as an action element, then you can have a parameter setting where you use a variable passed in from ICM.
Janine
Cisco Developer Community Forums wrote: > Peter Depalma has created a new message in the forum "General > Discussion - All Versions": > > -------------------------------------------------------------- > Hello, >  > Was wondering if there is any way to insert a delay in VXML. >  > I don't want to insert silent wav files, nor do I want to use microapps. >  > What I really needs is a delay element that could accept a numeric > value as a session variable I could pass from ICM...that way it can > be easily and quickly tweaked from the ICM script. >  > Any ideas, or anyone want to share an element they already have? >  >  > -- > To respond to this post, please click the following link: > > <http://developer.cisco.com/web/cvp/forums/-/message_boards/message/1374009> > > or simply reply to this email.
