Heads Up :
The post you are writing will appear in a public forum. Please ensure all content is appropriate for public consumption. Review the employee guidelines for the community here.
Created by: null on 29-09-2006 10:25:09 AM I am evaluating Audium. On two servers I have tried installing Call Services without success. When I follow all the default recommendation in the installation manual, I get the attached return when I try to open Hello World. I would appreciate your help with this. Thanks!
Subject: RE: Installation Problem Replied by: Michael Bochynski on 29-09-2006 04:18:59 PM Bill,
It looks like the server you are trying to access either does not have a license applied or the license is invalid. Please check your Tomcat console for additional information about the error message.
Note that we have already updated the software to print out more descriptive message instead of the Java error you are seeing. The fix should be included in the future release of Call Services.
Regards, Michael
Subject: Still stuck Replied by: null on 30-09-2006 12:56:10 AM I am still struggling. Looking at the log file it appears to be an AUDIUM_HOME problem. I have attached my web.xml file from the WEB-INF file in the sub directory of the Audium Folder that ends up in the Tomcat webapps folder. I have also included the localhost log file.
Hope you can help.
Subject: Still no progress Replied by: null on 02-10-2006 01:47:40 AM Having not heard back, I continue to try to solve this problem. The problem is perhaps not an Audium_Home problem afterall. Attached is the log from today after manually starting Tomcat. Please advise whether I need to request a new license (the one I applied successfully is a 1 month eval license that was applied succesfully last week for the first time) ore do something else.
Subject: RE: Still no progress Replied by: Michael Bochynski on 02-10-2006 03:39:58 PM Bill,
The actual error is logged to the â¿¿Catalina.outâ¿¿ file, if you start Tomcat either as a service or by typing â¿¿TOMCAT_HOME/bin/Catalina.bat startâ¿¿. If you start Tomcat by double clicking on â¿¿startup.batâ¿¿ file, the output is printed to the console. The exceptions you are getting in the localhost_log file are a derivative from the root error. Please send either the Catalina.out file or a console output, so we can see the root cause of the error.
Note also, that AUDIUM_HOME is the variable that points to the folder with your applications and custom code, by default C:\Program Files\Audium\CallServices.
Please also refer to the Audium Knowledge Base article for details on setting up the AUDIUM_HOME variable;
