cdnadmin
Community Member
This document was generated from CDN thread
Created by: Lizabeth Li on 29-09-2010 11:42:00 PM
I'm new to SOAP and CUCM.  I'm having an issue using the list requests for CUCM 8.0.x.
For instance, I am trying to use listDateTimeGroup:
<soapenv:Envelope xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/" xmlns:ns="http://www.cisco.com/AXL/API/8.0">
 <soapenv:Header/>
 <soapenv:Body>
  <ns:listDateTimeGroup sequence="1">
   <searchCriteria>
    <name>*</name>
   </searchCriteria>
   <returnedTags/>
  </ns:listDateTimeGroup>
 </soapenv:Body>
</soapenv:Envelope>
This is what I get in response:
<SOAP-ENV:Envelope SOAP-ENV:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/" xmlns:SOAP-ENV="[url=http://schemas.xmlsoap.org/soap/envelope/"><SOAP-ENV:Header/><SOAP-ENV:Body><SOAP-ENV:Fault><faultcode>SOAP-ENV:Client</faultcode><faultstring>No]http://schemas.xmlsoap.org/soap/envelope/"><SOAP-ENV:Header/><SOAP-ENV:Body><SOAP-ENV:Fault><faultcode>SOAP-ENV:Client</faultcode><faultstring>No method found for processing request</faultstring><detail><axl:Error xmlns:axl="[url=http://www.cisco.com/AXL/API/1.0"><axl:code>5003</axl:code><axl:message>No]http://www.cisco.com/AXL/API/1.0"><axl:code>5003</axl:code><axl:message>No method found for processing request</axl:message><request>listDateTimeGroup</request></axl:Error></detail></SOAP-ENV:Fault></SOAP-ENV:Body></SOAP-ENV:Envelope>
What am I doing wrong?
Thanks.
Subject: RE: Issue using list Requests
Replied by: Florian Kroessbacher on 01-10-2010 06:24:09 PM
I thinkyou should use % as the wildcard instead of * to search everything
cheers
Replied by: David Staudt on 04-10-2010 07:49:41 PM
Use '%' here.  The following works on my system:
POST https://10.88.131.139:8443/axl/ HTTP/1.1
Accept-Encoding: gzip,deflate
Content-Type: text/xml;charset=UTF-8
SOAPAction: "CUCMB ver=8.0 listDateTimeGroup"
User-Agent: Jakarta Commons-HttpClient/3.1
Content-Length: 375
Authorization: Basic QWRtaW5pc3RyYXRvcjpjaXNjbyExMjM=
Host: 10.88.131.139:8443
   <soapenv:Header/>
   <soapenv:Body>
         <searchCriteria>
            <name>%</name>
         </searchCriteria>
         <returnedTags/>
   </soapenv:Body>
</soapenv:Envelope>
Note 'listDateTimeGroup' is a request new to UCM 8.0(1)...I suspect you are executing this against a previous version.  If so, you will need to use <executeSqlQuery> with SQL something like:
select pkid,name from datetimesetting
Replied by: Lizabeth Li on 19-10-2010 10:29:41 PM
I had forgotten to include the SOAPAction header.  Thanks!
Content-Length: 375
   <soapenv:Header/>
   <soapenv:Body>
         <searchCriteria>
            <name>%</name>
         </searchCriteria>
         <returnedTags/>
   </soapenv:Body>
</soapenv:Envelope>
