cdnadmin
Community Member
This document was generated from CDN thread
Created by: null on 06-07-2004 07:14:20 AM
I am using Audium 3.3, and would like to build some custimized voice elements. Since I am using Java API, can I use "System.out.println()" to debug my java file? Or must I use the activity log? If I can use the Java standard output, where will the output go?
S.
Subject: RE: Java debug tool when building customised element in Audium 3.3
Replied by: Michael Bochynski on 06-07-2004 05:20:09 PM
Hi Sue,
Yes, you can use System.out.println() method in order to debug your custom code.
Your Java classes will use the application server's default output. Typically it would be the console, however, some application servers send their output to a file instead of a console. Please refer to your application sever documentation for details.
Michael
Replied by: null on 30-08-2005 01:00:12 PM
Just a note: a nice way to collect all your System.out.println debugging output is to start the Audium server with the "catalina run" command and redirect stdout to a text file. I have found this to be very handy at times. So for example, on a default windows CVP installation you could do the following:
c:/cisco/cvp/tomcat 4.1/bin/catalina run > c:/debug.txt
or you could also use log4j i suppose...
Replied by: Michael Bochynski on 30-08-2005 01:42:10 PM
Hi Peter,
Thanks for the tip! Moreover, if you install Tomcat as Windows service, all the console logs will be automatically stored in catalina.out file located in TOMCAT_HOME/logs folder.
Michael
Replied by: Michael Bochynski on 01-09-2005 06:26:35 PM
Sue, Peter,
We have just released a sample Debug element. It allows you to print out to console or log to a file Session and/or Element Data. The sample Debug element is available for download in our Sample Java code forum at:
http://www.audiumcentral.com/supportcenter/viewtopic.php?t=1562
Note that this element is provided as-is with full source code. We strongly suggest testing it before using in a production environment.
Michael
