sufle
Level 2
Level 2
Hi all,
Yesterday I've added DNS servers and domain names to the cluster. Nothing else has changed. Same IP's on all nodes.
Restarted the whole cluster, and everything worked fine.
DBReplication status is 2 on all nodes, which I understand is good.
But today it seems like it's having problems accessing database records, sometimes.
When I seach for Devices for example, every second time this error gets displayed:
"Error occurred during find. java.sql.SQLException: Could not do a physical-order read to fetch next row.
Then I just try again, and it works.
In device pool I had other error, when I tried to open one device pool, this error showed:
Error occurred while retrieving information from database. java.sql.SQLException: Could not position within a table (informix.device).
When I tried the second time, it opened it.
Has anyone seen anything like this?
Any help would be greatly appreciated.
George,
sufle
Level 2
Level 2
I've checked
utils dbreplication status
All seems fine. All nodes have same number of rows.
Greeshma Bernad
Thank you for  your posting and interest in the Cisco Support Community.  For best  practices on posting documents in this community you can refer to
https://supportforums.cisco.com/docs/DOC-6022#Can_I_use_documents_to_post_technical_questions
For  technical questions related to a Cisco Product or Technology, we  encourage you to post on the Network Professionals Forum (NetPro). For  your specific issue, you can go to IP  Telephony forum.
