Heads Up :
The post you are writing will appear in a public forum. Please ensure all content is appropriate for public consumption. Review the employee guidelines for the community here.
Created by: Ken Mills on 26-10-2010 05:33:19 PM I'm just getting started with JTAPI and had a couple of questions... 1. Is there a sample application that shows how to perform recording of a device? I have successfully used makeCall but wanted something closer to the functionality my app would be performing. 2. How do I set the destination RTP IP/Port when I want to record? I was hoping my application would supply this before I start recording but I don't see a JTAPI call to set that up only to get the settings the device will be using. Any help would be appreciated... Ken
Subject: RE: JTAPI: Device recording question Replied by: David Staudt on 26-10-2010 08:12:48 PM Unfortunately we don't have a working sample project for recording (a good idea), however note that CTI recording via the phone's built-in media bridge to fork media actually results in a complete second call from a phone to a DN. This DN must route to a SIP trunk connected to UCM, which is provided by the application. So in effect the app specifies its per call media IP/port by implementing a SIP trunk termination, and providing IP/port via standard SIP SDP signaling as each recording call comes in to the trunk. See the 'Cisco Unified CM Silent Monitoring & Recording Overview.ppt' document here: http://developer.cisco.com/web/sip/docs There is also a more detailed 'Cisco Unified CM Silent Monitoring & Recording Specification' which requires a CDN developer support contract to access, as some details of the SIP trunk implementation are Cisco proprietary extensions.
Subject: RE: JTAPI: Device recording question Replied by: Ken Mills on 26-10-2010 08:36:50 PM Thanks for the quick response and the links. Looks like I have a bit more research to do. Thanks again.
